intake manifold torque?
#2652258
05/05/19 01:36 PM
05/05/19 01:36 PM
Posts: 23 SoCal
droptail
SoCal
my service manual says 40 lb-ft for the (8) large bolts - but says nothing about the (6) small plate bolts front & rear?
' '70 Cuda convt - 383 bored/ported, Hemi cam, Rhoads, rollers, Mellings, MSD, 750 DP, LT dual 3", lowered, snubber, police chuck, discs, springs, sway bars, Transgo, posi, shaker, aluminum 17" rallyes w/275-285/40 EXTREMECONTACT SPORT, leather...
Re: intake manifold torque?
[Re: droptail]
#2652288
05/05/19 02:54 PM
05/05/19 02:54 PM
RapidRobert
"evenly snug" would likely suffice on that situation which is probably why no spec is given but a person could Google the torque spec (in lbs) for the grade/dia of those small bolts in question. Dont forget some sealer under the valley pan ends to keep the oil where it belongs.
[Re: RapidRobert]
#2652295
05/05/19 03:17 PM
05/05/19 03:17 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
I would not do 40 on an aluminum intake. Cast iron ok, but not aluminum. I believe I torque my aluminum manifolds with a good washer to 35 ft lbs. That should be adequate for a grade 5 bolt.
[Re: droptail]
#2652383
05/05/19 08:17 PM
05/05/19 08:17 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
All the factory service manuals I've used say 35 Ft..Lbs. on the 3/8 intake bolts, not 40 Ft Lbs. The 1/4 inch end bolts need to be tight, not twisted off As said some of the after market intake manifold specs. sheets call from 25 to 30 Ft. Lbs. I do retorque the intake bolts several times after driving it enough until the bolts take a final set and stop moving
[Re: Cab_Burge]
#2652523
05/06/19 10:31 AM
05/06/19 10:31 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
For torque specs when not in the FSM. Though the FSM used to have something similar in in. Do not change the spec just because it's clamping an aluminum manifold.
[Re: Supercuda]
#2655707
05/15/19 02:06 PM
05/15/19 02:06 PM
Posts: 23 SoCal
droptail
SoCal
