727 accumulator question (update another question)
#2652277
05/05/19 02:22 PM
05/05/19 02:22 PM
Posts: 327 wisconsin
mod381
wisconsin
I am building a 727 trans and I have read different thoughts on blocking the accumulator or leaving the spring out. Most of the threads that I searched on this were older. Just curious what the general opinions are if it should be blocked or just leave the spring out.
Re: 727 accumulator question
[Re: mod381]
#2652290
05/05/19 03:05 PM
05/05/19 03:05 PM
RapidRobert
street/strip/both. Not even sure if those apps make a difference but here is a BTT for ya.
[Re: mod381]
#2652315
05/05/19 04:22 PM
05/05/19 04:22 PM
Posts: 25,827 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Removing the spring has zero affect on any upshift, blocking the accumulator will firm the 1-2 upshift. If you're not gonna block the accumulator, install the spring.
[Re: mod381]
#2653422
05/08/19 03:18 PM
05/08/19 03:18 PM
John_Kunkel
Rio Linda, CA
You're OK the way you did it but you coulda waited until after assembly to install the set screw or just left the O ring off the plunger when assembling the piston assembly.
