Re: Dewalt air compressor?
[Re: sam64]
#2652146
05/05/19 10:13 AM
05/05/19 10:13 AM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
The smaller "pancake" style compressors are built in the Jackson Tn. plant I believe. But, I don't know about the larger units.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: 5thAve]
#2652265
05/05/19 01:53 PM
05/05/19 01:53 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Can't be 100% sure, but the larger 2-stage / consumer grade unit is made by MAT holdings and re-branded. If you look at the specs, and components they are identical to Industrial Air, Sanborn, Dewalt, etc. etc.
There are *very* few compressors that use 100% American parts. Especially the types that most of us can/want to afford. The HF units are built in USA, but use an Italian pump and Century motor (Ohio company, however built in Mexico).
There are tons of 60 gallon / single stage compressors out there with <5 HP motors. Not everyone needs that much CFM for hobby stuff.
It doesn't sound like you are running a body shop and know exactly your intended use. I say go for it if you believe it is a good deal. Like others said, maintain it, and it will likely be fine for a long time.
383, Hemi 4-Speed, AlterKtion, D60
