Page 8 of 10 1 2 6 7 8 9 10
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: JERICOGTX] #2651799
05/04/19 08:35 AM
05/04/19 08:35 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Yep......I think the guy name is Bo, who owns that charger. Sweet car up
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: racerx] #2651817
05/04/19 09:42 AM
05/04/19 09:42 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
that looks great!
68 Barracuda Formula S 340
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Bad340fish] #2651869
05/04/19 12:19 PM
05/04/19 12:19 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
That hood looks great, as you know I have a cowl hood, 2nd gen Chargers are the most difficult car to find a scoop that looks good, the car is so AWESOME looking stock, I did the cowl for cool air & hood clearance, it works very well, but as far as LOOKS go the hood you posted is the best LOOKING hood I have seen on a 2nd gen, it has that 3rd gen bulge hood look.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: CSK] #2652050
05/04/19 11:53 PM
05/04/19 11:53 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Exhaust is finished. Shifter next, then wiring!
[Linked Image]Untitled by Greg Ault, on Flickr
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2654445
05/11/19 10:29 PM
05/11/19 10:29 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Out with the old...! I needed a rear exit shifter with the new elephant pretty much eliminating any possibility of running a shifter cable through the engine compartment. wink
Old (PM if interested):
New:
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2658672
05/24/19 07:59 AM
05/24/19 07:59 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I've been fighting with the PPP bracket that connects the cable to the transmission. I ordered the one for use with a blanket and it flat out won't fit. It hits the floor and required so much trimming that it compromised the structure. Even after my hack job the bolt holes won't align up due to the cast transmission pan. Absolute junk in my opinion. I wrestled with the idea if Sh%&-canning the entire shifter set up, but JBODY replied to my "help" post with a really cool idea for a bracket (apparently I'm not the only one with this problem). Here's my "junk" solution; I hope it helps others. I went off the top of the rear "ear" of the transmission (JBODY went under). I don't think it matters as long as the cable doesn't bind. "All-in-all" I hit all gears and PARK smoothly with no binding. If you order PPP, buy the cheapest bracket possible as it is just used as a template for your fab work (still kind of pi$$ed about that one). mad
My PPP "help" thread.
PPP Bracket:
JBODY's solution:
[Linked Image]IMG_2974 by Greg Ault, on Flickr
[Linked Image]IMG_2975 by Greg Ault, on Flickr
[Linked Image]IMG_2976 by Greg Ault, on Flickr
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2661689
06/02/19 11:26 PM
06/02/19 11:26 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Prepping for my new "Thumper Carb!" Fuel lines are supposed to be good for ~10 years. Mine are12+, stiff, and cracking! Made a front mount for my regulators.
Thumber Carbs!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2662894
06/05/19 11:50 PM
06/05/19 11:50 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Thumper Carbs!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2663055
06/06/19 12:52 PM
06/06/19 12:52 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Cool beans. Great to see the progress.
Does this combination benefit from the adapter setup from a power standpoint, or is it more a case of making it all work together?
Rich H.
Esse Quam Videri
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: ZIPPY] #2663316
06/07/19 12:23 AM
06/07/19 12:23 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
MuscleMotors said it makes more power. I did some research for both NA and Nitrous and there is a lot of support for the combination. I'm going to give it hell and see what it runs before I second guess MM. I modified the Air Grabber Air Cleaner to work with the new Thumper Carb today. I'll post some pics tomorrow or Saturday when the new Glasstek hood arrives!
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2663499
06/07/19 01:31 PM
06/07/19 01:31 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Thank you, good info. I have the same manifold, maybe mine would benefit from similar induction.
Rich H.
Esse Quam Videri
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: ZIPPY] #2663520
06/07/19 02:34 PM
06/07/19 02:34 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
Indy offers a similar setup in their catalog. I posted the question on here before, but didn’t get any replies from people that tried it.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2663655
06/07/19 11:08 PM
06/07/19 11:08 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
https://www.indyheads.com/images/22.cat2014.pdf
[Linked Image]Indy-Intake by Greg Ault, on Flickr
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2664209
06/09/19 11:43 PM
06/09/19 11:43 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I stumbled across this that might be a nice upgrade later on. eek
https://store.racerdirect.net/30972...ystem-50-500hp-4500-to-4150-adapter.html
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2664211
06/09/19 11:54 PM
06/09/19 11:54 PM
That looks like a hand grenade with the pin out waiting to be thrown work grin
I have a bunch of NOS parts I've never used and may not ever use confused
I'll probably go with a blower or turbo set up instead devil
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: Cab_Burge] #2664216
06/10/19 12:03 AM
06/10/19 12:03 AM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
I've run up to a 200 shot on a factory crank and rods. grin Both MoparBilly and Monte gave me some pointers via PM(s) on this board and the old MoparChat, but I'm no expert. This new Hemi stands a chance of pushing my car to the limits of the chassis without nitrous. No-Prep 8th mile racing is getting popular out here in AZ. I'm keeping the old nitrous set up on the car until I see how it runs.
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2664944
06/11/19 10:53 PM
06/11/19 10:53 PM
Arizona, USA
gsmopar Offline OP
gsmopar  Offline OP
Arizona, USA
"Plumbing" is finished. The hood shows up tomorrow. Just need to finish the wiring and fix an alternator issue that I caused by removing the mechanical water pump. grin
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: gsmopar] #2665756
06/14/19 09:43 AM
06/14/19 09:43 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Looks nice. How soon until you can fire it up?
69 GTX 68 Road Runner
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: JERICOGTX] #2665774
06/14/19 10:47 AM
06/14/19 10:47 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Lookin good sir! up
Re: G's Mopar build thread (hemi, gerst, '69 Charger) [Re: ProSport] #2665821
06/14/19 12:51 PM
06/14/19 12:51 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Looking good. Should have went with a fogger.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
