Borgeson Power Steering Box #2652041
05/04/19 11:19 PM
05/04/19 11:19 PM
Portage Wisconsin
Lou_Steger Offline OP
Portage Wisconsin
Has anyone used one and what is your opinion on the feel?
Steering Box
Re: Borgeson Power Steering Box [Re: Lou_Steger] #2652066
05/05/19 01:16 AM
05/05/19 01:16 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I own one and its the best you can get atm before moving over to a rack and pinion setup - you need to beef up your k member and use locktite on the bolts for the box or they will loosen off - this also helps http://www.firmfeel.com/b_body_mopar_sector_support_kit.html
you may have to bend the bracket to match your k member to fit proper
Re: Borgeson Power Steering Box [Re: Lou_Steger] #2652074
05/05/19 05:39 AM
05/05/19 05:39 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've been running one for about 6 years already.
No complaints and certainly no regrets.
