"933" valve spring installed height #2651757
05/03/19 10:24 PM
05/03/19 10:24 PM
Chicagoland 'Burbs
SlickRS23 Offline OP
Chicagoland 'Burbs
Was wondering, are the mopar "933" valve springs installed at the stock height of 1.83" to 1.86" or at 1.875-1.880 height.
It's a 440 with '906 heads and .480 lift cam.
Thanks, Jeff
Re: "933" valve spring installed height [Re: SlickRS23] #2651777
05/04/19 12:19 AM
05/04/19 12:19 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
with a 480 lift you will be fine 1.860 to 1.880 .
they are strong reliable springs !
mine have been on engine for over 30 years and never failed 5800--6200 rpm .
12.3 @ 111 mph
Re: "933" valve spring installed height [Re: calrobb2000] #2651795
05/04/19 08:10 AM
05/04/19 08:10 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
those springs coil bind quickly. try to get 1.88" if you can. they won't take much lift.
