Mopar electronic distributor pig tail #2650480
04/30/19 10:42 AM
04/30/19 10:42 AM
Oologah, Oklahoma
Big Squeeze Offline OP
Oologah, Oklahoma
Where can I get one?
Pig tail link
If you can't handle the truth, you're living a lie.......
Re: Mopar electronic distributor pig tail [Re: Big Squeeze] #2650482
04/30/19 10:45 AM
04/30/19 10:45 AM
md
mopars4ever Offline
mopars4ever  Offline
md
A old distributor pick up plug can be used IIRC. I have this used one but it was cut close to the plug. I will mail it to you if you want it.
Re: Mopar electronic distributor pig tail [Re: mopars4ever] #2650485
04/30/19 10:55 AM
04/30/19 10:55 AM
Oologah, Oklahoma
Oologah, Oklahoma
Thanks, but I was hoping to find a new one locally....I thought Standard Ignition made one but my local parts store can't find it and I've googled with no luck...
Re: Mopar electronic distributor pig tail [Re: Big Squeeze] #2650502
04/30/19 11:49 AM
04/30/19 11:49 AM
On a side note people have suggested to spiral those wires together along their length
Re: Mopar electronic distributor pig tail [Re: Big Squeeze] #2650503
04/30/19 11:50 AM
04/30/19 11:50 AM
Pasadena, Texas
fal3 Offline
fal3  Offline
Pasadena, Texas
I bought one years ago when I converted to electronic distributor. Bought it from Dorman @ auto parts store.
Re: Mopar electronic distributor pig tail [Re: Big Squeeze] #2650512
04/30/19 12:20 PM
04/30/19 12:20 PM
The new replacement pickups come with them scope
I have bought them at junkyards off of old cars alsoup
Re: Mopar electronic distributor pig tail [Re: fal3] #2650529
04/30/19 01:12 PM
04/30/19 01:12 PM
Oologah, Oklahoma
Oologah, Oklahoma
I know have too...It must be discontinued because I can't find it....
Re: Mopar electronic distributor pig tail [Re: Big Squeeze] #2650532
04/30/19 01:15 PM
04/30/19 01:15 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Various other mopars have them over the years underhood some lighting etc, Can be used.
Re: Mopar electronic distributor pig tail [Re: buildanother] #2650574
04/30/19 03:21 PM
04/30/19 03:21 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Is it the same as a battery tender connector? Just a thought.... maybe a bad thought lol
Scott
1969 Super Bee, 383/4 speed
Re: Mopar electronic distributor pig tail [Re: StukaJU87] #2650603
04/30/19 04:21 PM
04/30/19 04:21 PM
Andrewh Online content
Andrewh  Online Content
literally just bought one on sunday from the local orielys.
It is in the trailer connectors section.
it is double ended, so you would have to cut off one end to wire it up.
was like 4 bucks.
https://www.oreillyauto.com/detail/...653?q=Trailer+Connector+2+pin&pos=57
Re: Mopar electronic distributor pig tail [Re: Andrewh] #2650642
04/30/19 07:45 PM
04/30/19 07:45 PM
WA
tman Online content
tman  Online Content
WA
Think I would get a new pickup with pigtail to keep wires continuous, unless you have a special pickup coil that you want to keep.
https://www.ebay.com/itm/OEM-Mopar-...9302940?_trksid=p2385738.m4383.l4275.c10
https://www.manciniracing.com/picoandleas.html
Re: Mopar electronic distributor pig tail [Re: tman] #2650659
04/30/19 08:20 PM
04/30/19 08:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What makes you think he needs it for the pickup side?
Don't be the exception.
Re: Mopar electronic distributor pig tail [Re: Andrewh] #2650685
04/30/19 09:55 PM
04/30/19 09:55 PM
Unless you wanted OE I would go with the O'reillys item & any 2 wire trailer pickup of that type would work fine & if needed you can alter rotor phasing by reversing the phasing on the 2 leads when you solder em together.
Re: Mopar electronic distributor pig tail [Re: Andrewh] #2650777
05/01/19 08:41 AM
05/01/19 08:41 AM
Oologah, Oklahoma
Oologah, Oklahoma
was like 4 bucks.
Is the one you bought the same size as the distributor connector? The ones I've found at the parts store look the same but they're smaller.
Re: Mopar electronic distributor pig tail [Re: Big Squeeze] #2650823
05/01/19 11:42 AM
05/01/19 11:42 AM
I'd go ahead & grab it & you cant go wrong for $4 & if it wont plug in to the other half then you are out only haveing to solder 4 wires instead of 2.
Re: Mopar electronic distributor pig tail [Re: Big Squeeze] #2650845
05/01/19 12:27 PM
05/01/19 12:27 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
was like 4 bucks.
I noticed that as well. The NSS wire harness uses the same 2 pin and a single pin to make the connections, the trailer plugs are 90% the same but slightly off. It will 'work' and make an electrical connection but not have the oem fit up.
Re: Mopar electronic distributor pig tail [Re: Supercuda] #2650949
05/01/19 04:07 PM
05/01/19 04:07 PM
WA
tman Online content
tman  Online Content
WA
Based on the title of this thread. But I see now its the other side.
Re: Mopar electronic distributor pig tail [Re: tman] #2650957
05/01/19 04:31 PM
05/01/19 04:31 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Pretty sure they interchange.
Re: Mopar electronic distributor pig tail [Re: mopars4ever] #2650969
05/01/19 05:03 PM
05/01/19 05:03 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Except it's a lot cheaper to just buy the pig tail to fix the non pickup side than it is to buy a new pickup, cut off the pigtail and splice it in.
