67 Belvedere Wiper Switch Removal #2650722
04/30/19 11:27 PM
04/30/19 11:27 PM
Sugarloaf, PA. USA
JamiePasson Offline OP
Sugarloaf, PA. USA
Hey Everyone,
I'm trying to get the wiper switch out of the dash on a '67 Belvedere II. Any tricks? The knob doesn't seem to want to pull off or unscrew from the switch shaft. Any help is greatly appreciated!
Jamie
Passon Performance 309 Turkey Path Sugarloaf, PA 18249 (570) 401 8949 www.passonperformance.com
Re: 67 Belvedere Wiper Switch Removal [Re: JamiePasson] #2650727
04/30/19 11:33 PM
04/30/19 11:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Is there a small notch on the knob that you can push a tab on?
Re: 67 Belvedere Wiper Switch Removal [Re: stumpy] #2650736
05/01/19 12:16 AM
05/01/19 12:16 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
I'm not following what you mean by push a tab onto? There is nothing that I can see on the knob. No set screw or anything.
Jamie
Re: 67 Belvedere Wiper Switch Removal [Re: JamiePasson] #2650738
05/01/19 12:19 AM
05/01/19 12:19 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Early ones had an Allen set screw, you will see it if it’s there.
The later ones just slide on the shaft. Possible someone glued it on.
They don’t have the tab.
Re: 67 Belvedere Wiper Switch Removal [Re: NANKET] #2650744
05/01/19 01:03 AM
05/01/19 01:03 AM
Sugarloaf, PA. USA
Sugarloaf, PA. USA
I GOT IT! Thank you for the help. It was just REALLY stuck on.
Jamie
