Tie rod adjusting sleeve question #2650471
04/30/19 10:17 AM
04/30/19 10:17 AM
Greenwood Lake, NY
fuelishnsilly Offline OP
Greenwood Lake, NY
Were the tie rod adjusting sleeves plated or were they a natural steel? I’m replacing the tie rods (inners and outers) as some are worn and would like to have the correct look to them. After degreasing then and soaking them in evaporust, it looks like the bolts were a black phosphate and the nuts, sleeves, and clamps were natural.
This is for my 69 RR.
inherited a 69 roadrunner from my grand pop.
Re: Tie rod adjusting sleeve question [Re: fuelishnsilly] #2650678
04/30/19 09:24 PM
04/30/19 09:24 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
What I've found is that the sleeves are somewhat of a gray phosphate, clamps are natural, and the bolts and nuts to be a darker black phosphate. What I've found with phosphating parts my self is that depending on the alloy of steel some will get darker than others.
Re: Tie rod adjusting sleeve question [Re: cudaize] #2650753
05/01/19 04:28 AM
05/01/19 04:28 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
After phosphating parts I usually apply RPM wax. This darkens the color from gray to almost black.
First photo is unwaxed, second is waxed.
Re: Tie rod adjusting sleeve question [Re: kentj340] #2651766
05/03/19 11:16 PM
05/03/19 11:16 PM
Greenwood Lake, NY
Greenwood Lake, NY
Thats the plan. I'm hoping to use RPM on all the bare metal stuff and the plated stuff to keep them all looking new.
