Re: Fuel tank: Strange rust-thru on original tank 71 Barracuda
[Re: Morty426]
#2650732
04/30/19 11:48 PM
04/30/19 11:48 PM
Posts: 203 Alabama
David1971
Alabama
What is the residue you are talking about? There should not be any residue. Whatever it is I bet it created a moisture barrier. It looked like glue residue...as if a portion of the felt pad was glued to the top of the tank. I may be wrong. Or it may be that the pad deteriorated to the point that it turned into a sticky substance.
[Re: fastmark]
#2651144
05/02/19 08:58 AM
05/02/19 08:58 AM
Posts: 203 Alabama
David1971
Alabama
Are you sure it’s not rusting from the inside out? The ECS is right up there in that area. I bet it rusted out because of that. I spread open the rust-through at one end of the crack and used a Maglite to look inside. Looks like you are 100% correct. The ECS upper chamber appears to be corroded. I would never expected to see a problem there. Usually you see issues on the bottom of the tank at the lowest point where moisture will settle. I will install a new Spectra tank for now and try to clean and repair the original later.
[Re: fastmark]
#2651420
05/02/19 11:42 PM
05/02/19 11:42 PM
Posts: 203 Alabama
David1971
Alabama
Auctually, its the top area that is more prone to the rust. It is exposed to the air AND the moisture. My oem ECS tank rusted out in my cuda when it sat for about three years with no use. Did you repair (possible?) or replace?
[Re: David1971]
#2651627
05/03/19 04:12 PM
05/03/19 04:12 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Fastmark, I apologize for dragging out this thread. But, I have one last question. Your eom ECS tank that rusted out after three years....Was the fuel that you were using 10% ethanol? If so, do you attribute the rust problem to the E10? David, The rust is from the lack of gas in the tank. If you had the tank full the chance of rusting on the inside is low. With little to no gas the rest is filled with air and depending on where you live determines moisture in the air. That leads to rust where you can get galvanic corrosion. Still with fuel in the tank you should use things like Heet or Sta-bil to help reduce moisture in the tank if storing for any length of time.
[Re: Morty426]
#2651648
05/03/19 05:34 PM
05/03/19 05:34 PM
Posts: 19,641 north of coder
moparx
my charger has sat since somewhere around 2006, with an almost full tank of gas. when this thing was first brought out of mothballs in 2000, [don't beat me too much ! ], the tank was really crusty, so i blasted the inside with sand, which removed the tern coating from the material, plus all the rust that was there. i put a large wix canister filter on the line just after it came from the tank. before use, i spent a BUNCH of quarters at the car wash to remove all the sand, and to make sure it was clean. that worked great, then it was parked again. i just bought a stainless tank from vans, so when it sits again, HOPEFULLY, it won't get TOO nasty inside. but, who knows ?
