Exhaust Manifold Stud BB Mopar #2650465
04/30/19 09:46 AM
04/30/19 09:46 AM
Czech Republic
69topless Offline OP
Czech Republic
I need to buy a new sets of the studs and just want to make sure, I choose the correct one. I have a standard exhaust manifolds, the drivers side is PN 2463107 and the passenger side is PN 2532464. Car is 69 Polara with non-hp manifold exhaust and 383 2bbl engine.
Is this a correct kit?
bolt kit bb mopar
Or, can you recommned any other kit? I snap one bolt on the passenger side next to the firewall and need to take care of it.
Thank you for your help up
Re: Exhaust Manifold Stud BB Mopar [Re: 69topless] #2650495
04/30/19 11:15 AM
04/30/19 11:15 AM
yes
Re: Exhaust Manifold Stud BB Mopar [Re: 69topless] #2650549
04/30/19 02:00 PM
04/30/19 02:00 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
440 source has them
Re: Exhaust Manifold Stud BB Mopar [Re: RapidRobert] #2650913
05/01/19 02:32 PM
05/01/19 02:32 PM
Czech Republic
Czech Republic
Thank you both for confirmation of the correct parts fury beer
Re: Exhaust Manifold Stud BB Mopar [Re: 69topless] #2650916
05/01/19 02:38 PM
05/01/19 02:38 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Not associated per-se, but,
I like to put brass washers under the 4 out side nuts as they like to break from expansion and contraction.
I have mechanical Aptitude.
I can screw up anything.
Re: Exhaust Manifold Stud BB Mopar [Re: bboogieart] #2651615
05/03/19 03:32 PM
05/03/19 03:32 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Only change the studs that need to be I made the mistake of changing all the studs for good measure on a 440 I was rebuilding,it took lots of heat to remove them & the new ones fit loose & leaked coolant until the eng.warmed up.
Re: Exhaust Manifold Stud BB Mopar [Re: 71GTX471] #2651845
05/04/19 11:23 AM
05/04/19 11:23 AM
moparx Offline
moparx  Offline
did you use any sealer on the studs into the head ? i use loctite #567 [part #56765] high temperature, good for all metals, and gasoline, petroleum oils,natural gas, propane, and butane. great stuff in my opinion and experience.
beer
