440 Crank ID, Cast or Steel? #2649931
04/28/19 03:17 PM
04/28/19 03:17 PM
NW New Jersey
RSI700VIPER Offline OP
NW New Jersey
Is there any way to tell if a 440 crank is cast or steel (late vs early) when it's installed in the car besides looking at the harmonic balancer? Is there something different about the crank/balancer key, depth of damper bolt or threads, or something different on the rear flange etc.? Without knowing the correct balancer, will I need to drop the pan to check the crank to be sure?
1970 Superbird 440 Six BBL, 4-Speed, Dana, FJ5
1969 Daytona Charger 440 4-Speed, Dana, EV2
1971 340 Challenger Conv. Flemington Speedway Pace Car, FC7
1970 340 Six Pack Callenger T/A 4-speed T8 Tan
1971 340 Challenger RT Formal Roof, EV2 w/ V2 Stripe & Orange Houndstooth
1969 Talladega Torino, 428CJ
1969 Gurney Special Cyclone Spoiler II, 351 Cleveland
"Id rather have a bottle in front of me than a frontal lobotomy" Ben Franklin 1755
Re: 440 Crank ID, Cast or Steel? [Re: RSI700VIPER] #2650096
04/29/19 07:33 AM
04/29/19 07:33 AM
VA
dragon slayer Offline
VA
Drop pan, since no balancer there is no other distinguish mark from what I have seen, just on the nose of the crank.
Re: 440 Crank ID, Cast or Steel? [Re: dragon slayer] #2650208
04/29/19 01:10 PM
04/29/19 01:10 PM
Locomotion Offline
Locomotion  Offline
Do you know anybody with one of those flexible bore cameras, or whatever they are called? Might be able to get a view through the drain plug to see if the parting lines in the crank are thin (cast) or wide & flat (forged). Maybe even find a number on it.
It might depend on just how it was balanced if rebuilt as well. Internally with mallory metal, with OEM weight parts or aftermarket, etc. Might need a counterweighted flexplate too if its all not "neutral".
Re: 440 Crank ID, Cast or Steel? [Re: Locomotion] #2650215
04/29/19 01:31 PM
04/29/19 01:31 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Assuming it’s stock and still in the car Check for weights welded to the converter. Two small squares.
All cast crank big blocks I’ve had have had them stock. Doesn’t mean someone didn’t change it along the way.
Big Block Purple Camshaft [Re: RSI700VIPER] #2650218
04/29/19 01:35 PM
04/29/19 01:35 PM
Penticton, B.C. Canada
65_Satellite Offline
Good morning all,
I have a purple camshaft that I got in a trade several years ago. It is painted purple between the lobes , and has the numbers 911525 on the butt end of the shaft. I do not know if this is for a hydraulic or solid lifter cam nor do I know the specs any help would be very much appreciated, thankyou
Re: 440 Crank ID, Cast or Steel? [Re: dragon slayer] #2650238
04/29/19 02:51 PM
04/29/19 02:51 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
as I recall from the 70's forged had a wide parting line (1/2 inch) looking straight front to back, cast had a thin sharp line
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 440 Crank ID, Cast or Steel? [Re: Locomotion] #2650275
04/29/19 04:48 PM
04/29/19 04:48 PM
NW New Jersey
NW New Jersey
Bore scope - not a bad idea. I think I know someone who has one. It's a 4-speed and I'm told that the car should have a 10.5 inch flywheel with 2-holes drilled all the way through the flywheel next to one of the flex plate mounting bolts (thanks Wayne from Brewers!) since its a V code and should have the heavy rods. I will check for that also.
Re: Big Block Purple Camshaft [Re: 65_Satellite] #2650296
04/29/19 05:45 PM
04/29/19 05:45 PM
65_Satellite
Good morning all,
I have a purple camshaft that I got in a trade several years ago. It is painted purple between the lobes , and has the numbers 911525 on the butt end of the shaft. I do not know if this is for a hydraulic or solid lifter cam nor do I know the specs any help would be very much appreciated, thank you
Re: Big Block Purple Camshaft [Re: 65_Satellite] #2650299
04/29/19 05:58 PM
04/29/19 05:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by 65_Satellite
65_Satellite
Good morning all,
did you start your own thread ?
Re: 440 Crank ID, Cast or Steel? [Re: RSI700VIPER] #2650740
05/01/19 12:29 AM
05/01/19 12:29 AM
dogdays Offline
dogdays  Offline
IF the engine has never been apart, and it has a cast crank there will be a letter "E" on the engine ID pad.
Except for a 1969 model year engine, on that the E for '69 is the letter before the displacement.
The first counterweight on a cast 440 crank has "440" cast onto it, big as anything.
