Re: Pinion Depth Shim?
[Re: 451Mopar]
#2650217
04/29/19 01:34 PM
04/29/19 01:34 PM
Posts: 11,532 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
What combination of shims is in it? What does it look like with the 010? Fiddle with the backlash some. Take a few thou out and adjust the amount of torque on the nut.
[Re: 451Mopar]
#2650277
04/29/19 04:54 PM
04/29/19 04:54 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
Don't try to remove material from the shim or the bearing you will not be able to keep the parallelism within tolerance. How muck shim is in there now? can you swap out different shims to getteh overall number you need? If not try the .010 shim and see where that gets you if no good hunt down a .008.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: MR_P_BODY]
#2650416
04/30/19 01:55 AM
04/30/19 01:55 AM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You could put that shim on a surface grinder with a magnetic table and coolant I've had that done on an end play shim for an N14 Cummins camshaft when I couldn't get the right one and while it will work, the magnetic table doesn't have a lot of bite on .010" so you have to go GENTLY. Any more than a tenth or two at a time if that and the shim will walk on the table or worse. Kevin
[Re: Twostick]
#2650511
04/30/19 12:20 PM
04/30/19 12:20 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Seems like the easiest thing is to just get a set of shims from Raytech or Randy's.
[Re: MR_P_BODY]
#2650658
04/30/19 08:18 PM
04/30/19 08:18 PM
W.I.N. Racing
Byron, NY
You could put that shim on a surface grinder with a magnetic table and coolant How many people on here have access to a surface grinder??? cheaper to get a shim pack!
[Re: W.I.N. Racing]
#2650714
04/30/19 11:03 PM
04/30/19 11:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You could put that shim on a surface grinder with a magnetic table and coolant How many people on here have access to a surface grinder??? cheaper to get a shim pack! I do.. at my brothers shop
