Best Way to Strip and Refinish Steel Rim #2609311
01/20/19 01:49 PM
01/20/19 01:49 PM
MD
floyd Online content OP
floyd  Online Content OP
MD
This is a pretty rare rim with a fair amount of rust. Thoughts on chemical stripping vs. media blasting? It looks worse in the photo than it is, but I do expect some pitting. Would an aluminum oxide media do better against whatever pitting there is or am I better off chemically stripping? Either way, a full primer will be needed I assume.
Thanks!
Re: Best Way to Strip and Refinish Steel Rim [Re: floyd] #2609319
01/20/19 02:07 PM
01/20/19 02:07 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
glass or alox will be fine. dont go too nuts on the grit size though. something around a 70 grit will get you a .5 mil profile and clean out any rust pit holes and still retain whats left of your numbers. Be mindful that there is no media stuck in the 4 parts of the face that sit against the outer ring. lots of wheels have a sealer there that can cause issues with media being stuck in there after blasting.
Re: Best Way to Strip and Refinish Steel Rim [Re: floyd] #2609354
01/20/19 03:25 PM
01/20/19 03:25 PM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Agree glass is cleanest, hold your blast gun away from the surface a good distance, turn down pressure if needed and sneak up on it. High pressure and heavy grit will take the shortest amount of time but may remove stampings as well. Remember to shoot at heavy angles across the surface (parallel to the surface being blasted) where you expect numbers. If fine pitting exists after blasting, you may want to evaporust as well.
Whats the wheel going to be used for?
Remaining pit locations as well as final use of the wheel will determine how you address what you find beneath.
Good luck
Re: Best Way to Strip and Refinish Steel Rim [Re: floyd] #2609381
01/20/19 04:27 PM
01/20/19 04:27 PM
A727Tflite Offline
A727Tflite  Offline
Word of caution when dipping a wheel or blasting with fine media in the area of the web to rim joint.
I have seen several light colored wheels with rust starting to migrate from this seam.
Have it e-coated or saturate this joint with self etching primer, multiple applications.
Then perform the remainder of your wheel prep before paint.
Re: Best Way to Strip and Refinish Steel Rim [Re: A727Tflite] #2609401
01/20/19 05:06 PM
01/20/19 05:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
On a couple rallye wheels I cleaned up I used EvapoRust down in the seam area. Before spraying the wheels with epoxy primer I poured a little reduced primer in the seam and rolled it around to help seal it.
On a wheel like that you can pack modeling clay in the open slots from behind and then pour a little Evaporust in the seams. The clay should seal it long enough for the Evaporust to work. Might want to put the wheel on some newspaper or plastic sheeting just in case you get a little seepage.
If you take steel wheels to have them blasted and powder coated here you'll get back a wheel with media bits packed into the seams and very little coating in the joint. First couple times the wheel gets wet you'll have rust starting. Expensive and no attention to detail so I just do them myself with good primer and paint.
Re: Best Way to Strip and Refinish Steel Rim [Re: floyd] #2609440
01/20/19 06:32 PM
01/20/19 06:32 PM
MD
MD
Thanks for all the suggestions. Much appreciated!
Re: Best Way to Strip and Refinish Steel Rim [Re: floyd] #2609571
01/20/19 10:07 PM
01/20/19 10:07 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Degrease first, lots of heavy duty detergent then HOT steam cleaner/pressure washer. Then overnight in Evaporust. Then use a chemical stripper to remove paint. Once stripped give it another steam cleaning treatment with detergent. Use Ospho (or similar acid wash with a phosphate residual) to clean bare metal and neutralize any flash rust. This should result in a bare rim with no additional blasting required. Treat the pits like bodywork, add filler in bad areas, use high build primer for lighter areas, sand away almost all of it so only the filled pits with filler/primer are remaining against the clean bare steel.
If striving for absolute originality don't use a primer coating, just paint per factory. Most were sprayed gloss black (factory used cheap paint, was not very glossy) on the backside, then color was shot onto the outside with no hole masking allowing for color overspray onto the black through the holes.
.02
Re: Best Way to Strip and Refinish Steel Rim [Re: ScottSmith_Harms] #2609747
01/21/19 04:40 AM
01/21/19 04:40 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
.02
iagree
Re: Best Way to Strip and Refinish Steel Rim [Re: Morty426] #2649783
04/28/19 09:04 AM
04/28/19 09:04 AM
MD
MD
Thought I'd post a picture of the results after the evaprust bath. That stuff is pretty amazing. In hindsight, I should have sprung for more than 3.5 gallons. It was a bit of a challenge soaking one third of the rim at a time. Before picture at the top of this post.
Re: Best Way to Strip and Refinish Steel Rim [Re: floyd] #2649787
04/28/19 09:13 AM
04/28/19 09:13 AM
KY
65pacecar Offline
65pacecar  Offline
KY
Evaporust works great. Harbor Freight carries it and they will let you use the 20 or 25% coupon with it.
Re: Best Way to Strip and Refinish Steel Rim [Re: 65pacecar] #2649791
04/28/19 09:22 AM
04/28/19 09:22 AM
MD
MD
Thanks - I will check that option out. Fastenal carries it too, but I haven't many coupon/discounts available.
Re: Best Way to Strip and Refinish Steel Rim [Re: 65pacecar] #2649792
04/28/19 09:23 AM
04/28/19 09:23 AM
WV
Little Detroit Offline
WV
my local machine shop bakes them in an oven used by most machine shops to bake grease and grime dry and then after cooling puts them in a bead blaster which knocks off" all" of the dried grease and grime of completely , leaving a nice clean metal finish with no residue or sandblasted finish. a set usually runs about $100.00 .
Re: Best Way to Strip and Refinish Steel Rim [Re: Little Detroit] #2649795
04/28/19 09:41 AM
04/28/19 09:41 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Lye eats grease and paint. Turns it into soap and goo. Doesn't harm steel no matter how long you leave it in, but it EATS aluminum. After the lye does its magic, pressure wash. Lye doesn't touch rust, so use Evaporust after the pressure washer.
Re: Best Way to Strip and Refinish Steel Rim [Re: John Brown] #2650863
05/01/19 12:55 PM
05/01/19 12:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have always just sand blasted, putty fill any pits, sand, prime and paint to match.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Best Way to Strip and Refinish Steel Rim [Re: Little Detroit] #2651065
05/01/19 09:54 PM
05/01/19 09:54 PM
Rochester NY
Jer Offline
Jer  Offline
Rochester NY
Originally Posted by Little Detroit
my local machine shop bakes them in an oven used by most machine shops to bake grease and grime dry and then after cooling puts them in a bead blaster which knocks off" all" of the dried grease and grime of completely.
Same here. He bakes them, then locks them into a tumbler to clean them up. Clean surface, not 'pitted' like blasting.
Re: Best Way to Strip and Refinish Steel Rim [Re: 6PKRTSE] #2651177
05/02/19 11:06 AM
05/02/19 11:06 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
this would be the easy way. for some reason there are some really bad blasters out there who have ruined the whole industry and left people scared to get anything blasted. Moparts has its experts and they like to say that their process is the best. (which is just might be) but I guess its the difference in doing a 20 year resto or actually just getting the job done in a couple hours.
i have blasted hundreds of rims, i don't get media stuck in the seams. I must have just been lucky i guess. i dont knock off number stampings or make some massive surface profile in the steel like everybody is scared of. despite the moparts popular opinion blasting steel wheels will not blow holes through them or cause them to warp. lol
Re: Best Way to Strip and Refinish Steel Rim [Re: chrisf] #2651436
05/03/19 01:55 AM
05/03/19 01:55 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
You don't need to invest in sand blast equipment or pay somebody to sand blast. As said above, degrease and paint strip. Clean up the paint stripper with mineral spirits, and dip in Evapo-Rust for a day or two. Clean up the Evapo-Rust with mineral spirits and apply a phosphoric acid such as Rust-Cure or Ospho. Clean off excess phosphoric acid with mineral spirits again and paint.
I had planned to get a large air compressor and a big sand blast cabinet, but after working with Evapo-Rust, there's no need. Evapo-Rust isn't cheap, but it's a whole lot cheaper than a large compressor and a big sand blast cabinet. You can buy 5 gallons for $80 from northerntool.com with zero freight cost if you pick up at their store. Even 50 gallons at $800 would cost quite a bit less than a big air compressor. And the results are just as good or better.
I did 5 wheels like this. Works out to $16 a wheel just for the Evapo-Rust. And the Evapo-Rust isn't depleted yet.
Re: Best Way to Strip and Refinish Steel Rim [Re: chrisf] #2651645
05/03/19 05:24 PM
05/03/19 05:24 PM
moparx Offline
moparx  Offline
my bigest problem is i live in the rust belt, and stuff gets a little pitted. at work, we used a steel shot blaster, and that blended the pits into a uniform surface finish. what stuff [grit ?] do you use as blast media ?
beer
Re: Best Way to Strip and Refinish Steel Rim [Re: kentj340] #2651762
05/03/19 10:43 PM
05/03/19 10:43 PM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
EvapoRust works great but I'll save you even more money. Use vinegar at $1.00 a gallon and leave it in for two days and rust will be gone. I restored a drill press and car parts this way. Just paint or coat quickly before flash rusting.
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Best Way to Strip and Refinish Steel Rim [Re: 340wedge] #2651825
05/04/19 10:07 AM
05/04/19 10:07 AM
moparx Offline
moparx  Offline
how much prep should a guy do to the wheel before dunking it in vinegar ? grease/paint removal wise ?
beer
