6.1 Cam recommendation #2649323
04/26/19 03:02 PM
04/26/19 03:02 PM
Scatchamatoon
Saskabusa Offline OP
Scatchamatoon
Looking for advice on a cam swap in a Hemi.
The motor is an 06 SRT8 6.1 out of a Charger. It is stock except for TTI headers. The rest of the exhaust is 3" with dynomax mufflers.
It is in a 1968 Charger with a Tremec five speed transmission. The rear axle is 3.91.
This is my brothers car, he would like more power and for it to sound meaner.
I think it already sounds good as is.
This car gets driven on nice summer days will very rarely go to a drag strip and never sees cold weather.
I am not familiar with cam specs in new Hemis.
If this was a big block I would think about a 280 or 284 degree cam for it.
Any suggestions?
1974 Roadrunner
1967 Charger
Re: 6.1 Cam recommendation [Re: Saskabusa] #2649393
04/26/19 07:18 PM
04/26/19 07:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Comp 273 will do what he wants. It's got much more of the old musclecar sound and feel.
https://youtu.be/cbFjm6kSIPE
Rich H.
Esse Quam Videri
Re: 6.1 Cam recommendation [Re: ZIPPY] #2649726
04/28/19 12:36 AM
04/28/19 12:36 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I’m running a 219/231 on a 112 in a stock block 6.1, its the biggest you would want in a stock block. It’s still tame as far as hemi cams go.
pm gremlinsteve on here, it’s his grind.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
