Re: BEST BATTERY FOR TRAILER WINCH [Re: pittsburghracer] #2649367
04/26/19 05:18 PM
04/26/19 05:18 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
This might help you guys. When your pulling your trailer,you will automatically charge your trailer battery if you hook the #4 lead to your trailer battery. If you have a 7 lug connector.
Re: BEST BATTERY FOR TRAILER WINCH [Re: OUTLAWSSAA] #2649523
04/27/19 10:58 AM
04/27/19 10:58 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Use (2) deep Cycle Golfcart batteries...
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: BEST BATTERY FOR TRAILER WINCH [Re: racerhog] #2649554
04/27/19 02:41 PM
04/27/19 02:41 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
It sounds like you do not need a lot of power. If a lawn tractor battery has enuff oomph to run the winch, that is your cheapest at $30 a pop. Just keep it charged and replace it every couple years.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: BEST BATTERY FOR TRAILER WINCH [Re: 68LAR] #2649580
04/27/19 03:56 PM
04/27/19 03:56 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Originally Posted by 68LAR
Originally Posted by DynoDave
I have a Duracell (Made in the USA) Marine/RV battery from Sam's Club in my car hauler. Works great. Charge as needed in season, pull and store on shop bench with a Battery Tender during the winter.
I don't belong to Sams club, but my daughter does. What was the cost of your battery??
Can't recall. Let me hunt up the receipt.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: BEST BATTERY FOR TRAILER WINCH [Re: DynoDave] #2649589
04/27/19 04:33 PM
04/27/19 04:33 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
August of '17, Duracell 24dc item # 347618, $74.87 with $18.00 core.
DynoDave
Member # 12304
Re: BEST BATTERY FOR TRAILER WINCH [Re: DynoDave] #2650191
04/29/19 12:27 PM
04/29/19 12:27 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
What I did was because I never wanted to have a dead battery for the winch. I put a solenoid under the hood of my truck directly to the battery. and ran welding cable back to the rear bumper. Then installed a 50 amp two pole anderson connector plug on the rear bumper with the corresponding plug on the trailer. Start the truck hit the switch for the solenoid and you have all the power you need. Cost is about $140 and never needs replacing. I also cut the clamp ends off a pair of jumper cables and put another anderson connector on. Now I can jump start something without opening the hood.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: BEST BATTERY FOR TRAILER WINCH [Re: FurryStump] #2650248
04/29/19 03:33 PM
04/29/19 03:33 PM
South Park, Pa.
68LAR Offline OP
68LAR  Offline OP
South Park, Pa.
What I've done is run a wire from power plug of trailer to positive term of winch battery. The truck charging system charges the winch battery while I'm driving.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: BEST BATTERY FOR TRAILER WINCH [Re: 68LAR] #2651092
05/01/19 11:25 PM
05/01/19 11:25 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Could you not run some cable from the battery of the truck and just use that? If you're winching start the truck up?
Re: BEST BATTERY FOR TRAILER WINCH [Re: WO23Coronet] #2651250
05/02/19 02:43 PM
05/02/19 02:43 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My truck also charges my battery on both my open trailer and enclosed trailers for the winches while driving down the road. I never buy any special battery. Whatever is on sale. I usually seem to get 7-8 years out of them.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: BEST BATTERY FOR TRAILER WINCH [Re: CMcAllister] #2652329
05/05/19 05:25 PM
05/05/19 05:25 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Costco sells Interstate for what ever it’s worth. What is interesting they come with a 42 no co-pay/or warranty across the counter exchange. Their pricing is very good.
