Page 1 of 4 1 2 3 4
Removing power valve #2648621
04/24/19 09:20 PM
04/24/19 09:20 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
On a holley, when removing the power valve, do you jet up on just the primary or both circuits ? thanks !
Re: Removing power valve [Re: varunner] #2648624
04/24/19 09:24 PM
04/24/19 09:24 PM
AndyF Online content
AndyF  Online Content
You add jet to the metering block which you removed the power valve from.
Re: Removing power valve [Re: AndyF] #2648635
04/24/19 09:36 PM
04/24/19 09:36 PM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
thanks Andy, generally how many sizes ? I've heard anywhere from 2 - 10
Re: Removing power valve [Re: varunner] #2648642
04/24/19 10:05 PM
04/24/19 10:05 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Usually 8-10 jet sizes. If you have the option, plug the PVCR's also.
Re: Removing power valve [Re: varunner] #2648653
04/24/19 10:22 PM
04/24/19 10:22 PM
Which end of the carb are you removing the P.V. from? Why aren't you wanting use it?
Re: Removing power valve [Re: Cab_Burge] #2648665
04/24/19 11:24 PM
04/24/19 11:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
"Why aren't you wanting use it?"
THIS^^^
Boffin Emeritus
Re: Removing power valve [Re: varunner] #2648694
04/25/19 07:44 AM
04/25/19 07:44 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
8 sizes should do it.I have jetted 6 up on pri and 8/10 on sec and this will also help you know how your carb uses fuel.Be sure to not let the pv gasket leak.pump fuel will take less adjustment than race gas
Re: Removing power valve [Re: varunner] #2648706
04/25/19 08:13 AM
04/25/19 08:13 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The change in the main jet will depend on the size of the PVCRs under the power valve. You can take drill bits and measure the PVCR size and then with a little math figure how much bigger the mains need to be. It won't be exact, but will get a good close starting point for the rest of the tuning.
Power valves and PVCRs are good tuning tools. Rarely do they need to be eliminated, at least on the primaries.
Master, again and still
Re: Removing power valve [Re: Clanton] #2648707
04/25/19 08:13 AM
04/25/19 08:13 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
so I'm having a heck of a time getting this engine to idle decent. Seems way too rich. Plugs are wet, inside of intake usually looks wet. It's 383 stock eliminator engine. It has 7-9 in. of vacuum at idle. The carb, R4668, w/vac secondaries, came from a carb guy with a 3.5 PV, I put a 2.5 in there, and it may have helped, not sure. So at this point I'd just like to get it out of there and see how it responds. The mixture screws seem to work right, and all butterflys have had a hole put in the them. Secondary block doesn't have a PV. Also the motor seems to run lean at WOT, this was seen on the dyno, 13.2, and inside of headers are white.
Re: Removing power valve [Re: varunner] #2648708
04/25/19 08:17 AM
04/25/19 08:17 AM
New York
polyspheric Offline
polyspheric  Offline
New York
It should NOT idle on the PV, something is wrong.
Reason#1 for "Take it out" advice: doesn't understand what it does.
Boffin Emeritus
Re: Removing power valve [Re: varunner] #2648715
04/25/19 09:00 AM
04/25/19 09:00 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
How many turns out are the idle metering screws?
Re: Removing power valve [Re: polyspheric] #2648723
04/25/19 09:29 AM
04/25/19 09:29 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
agreed it shouldn't. if removed, it won't. not sure how much you actually know about a holley on a stocker motor, but if you check around, most people remove them, just to simplify things. This engine will either be at idle or WOT, nothing in between.
Re: Removing power valve [Re: varunner] #2648727
04/25/19 09:48 AM
04/25/19 09:48 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Often times, removing the PV will slightly improve the “hit” on the line.
I’d take it out and see what happens........ easy enough to put it back in.
Do the OE bowls have site plugs?
If not, I’m guessing the floats are a little too high, and/or the fuel pressure is slightly too high.
Holes in all 4 butterflies?
Better check the wording on that in the rules.
We had an issue with that years ago.
We had to replace the rear blades(with some that had no holes) before we could continue running, and they disallowed our qualifying runs.
An easy test is lift the carb off the manifold an inch or so, and block it up with something.
Turn on the fuel pump and see if any fuel starts dripping from anywhere underneath.
I’ve seen fuel dripping out from places where it theoretically “couldn’t”.
Re: Removing power valve [Re: fast68plymouth] #2648735
04/25/19 09:52 AM
04/25/19 09:52 AM
Get-X Offline
Get-X  Offline
Yup, I've seen guys get bounced for having the wrong head on the butterfly screws, let alone modding the butterfly's themselves.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Removing power valve [Re: Get-X] #2648741
04/25/19 10:01 AM
04/25/19 10:01 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Your cam may enough duration that the signal is poor. Then it need more air to idle. Craig king the CV throttle blades exposes the transfer slot. Now the idle mixture is a mess. What you need is an air sorce to get the idle speed up without opening the blades or drilling the plates. Get creative, leaky PCV valve, base gasket, ect. Then it may take some adjustment to the idle air bleeds as well.
Doug
Re: Removing power valve [Re: Clanton] #2648754
04/25/19 10:23 AM
04/25/19 10:23 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
1 1/2
Re: Removing power valve [Re: fast68plymouth] #2648756
04/25/19 10:26 AM
04/25/19 10:26 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I agree, easy to do.
no site plugs
in this day and age in stock, holes in butterflys I'm not worried about.
will definately lift the carb and if it drips. fuel pump pressure is 6 lbs.
Re: Removing power valve [Re: dvw] #2648757
04/25/19 10:26 AM
04/25/19 10:26 AM
So. Burlington, Vt.
So. Burlington, Vt.
Unless the wording in the rule book has changed, drilling holes in the primary blades is legal....... and no mention of size limits, so they can be big enough to get plenty of air thru to attain a decent idle.
Generally the idle circuit in a factory carb will need some enrichment to supply enough fuel to achieve a decent idle with a cheater cam that has low vacuum.
Perhaps the mods that were done are a bit on the rich side already.
But I strongly suspect there is fuel flowing that’s independent of the motor running.
Re: Removing power valve [Re: DaveRS23] #2648758
04/25/19 10:28 AM
04/25/19 10:28 AM
Virginia
V
varunner Offline OP
varunner  Offline OP
V
Virginia
I'll measure that and record.
I only have a very small amount of the transfer slot exposed.
thanks all.
Re: Removing power valve [Re: varunner] #2648761
04/25/19 10:34 AM
04/25/19 10:34 AM
So. Burlington, Vt.
So. Burlington, Vt.
I wouldn’t be trying to get it to idle at a low-ish rpm either........ 12-1300 in neutral, hot...... is where I’d be.
And, unless the car was moving........ it wouldn’t be in gear.
Page 1 of 4 1 2 3 4
