1969 Charger Belt Diagram #2648369
04/24/19 09:07 AM
04/24/19 09:07 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Good Morning Everyone.
Does anyone have a diagram (or pictures) of how all the pulleys run for a 1969 Charger 440 Automatic
with Air Conditioning and Power Steering? I have a 3 groove pulley on the crank and a 2 groove pulley
on the water pump. Is this enough?
Thanks!!
Re: 1969 Charger Belt Diagram [Re: jim6346] #2648580
04/24/19 07:22 PM
04/24/19 07:22 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
It's in the service manual somewhere, Can't remember which section shruggy
The manual is online and down loadable at MANUAL LINK
beer
Re: 1969 Charger Belt Diagram [Re: TJP] #2648593
04/24/19 08:02 PM
04/24/19 08:02 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
69 fsm
Don't be the exception.
Re: 1969 Charger Belt Diagram [Re: jim6346] #2648682
04/25/19 03:18 AM
04/25/19 03:18 AM
southeast NE
lemondana Offline
lemondana  Offline
southeast NE
With factory AC your bottom pulley should have 4 grooves and your water pump pulley should have only one groove. Sounds to me like somebody cobbled something together there.
Re: 1969 Charger Belt Diagram [Re: Supercuda] #2648729
04/25/19 09:49 AM
04/25/19 09:49 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Supercuda, you are awesome, thanks!!
Yes, I now have a 4 groove pulley for the crank and a single pulley for the waterpump.
Had to order an idler pulley, was not aware of that.
Thanks!!
Re: 1969 Charger Belt Diagram [Re: jim6346] #2648923
04/25/19 04:05 PM
04/25/19 04:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I might be awesome, though I suspect many would disagree, but TJP hooked you up with the ultimate source, a link to the FSM for yourself.
