Re: sfi case for a mopar tqflight 727
[Re: dvw]
#2649082
04/25/19 11:16 PM
04/25/19 11:16 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Besides the drum exploding what will total a stock case handle?? I am putting well over a 1000 hp through a stock one and had to upgrade some internals like the drum and planets.
[Re: moparx]
#2649232
04/26/19 11:13 AM
04/26/19 11:13 AM
Posts: 6,561 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
how can the case work with the 727 plus all the OD variants ? i thought where the OD bolted up, there are different hydraulic circuits, or are these blocked off somehow to allow this case to be used as a 727 ? I wondered that myself. It would be nice to be able to put a 518 behind a 440 without a bunch of cobbled up band aids to make it happen but the price point this piece will land at IF it ever gets made will make that a nonstarter. Kevin
[Re: Leigh]
#2649330
04/26/19 03:25 PM
04/26/19 03:25 PM
Posts: 31,016 Oregon
AndyF
Up here, the salt eats away at the starter register. The last time I helped a guy convert to a big block, three cases were junk in that area. It wasn't easy to even locate B, RB trans. I ended up buying an nos case from Rick, at A&A. I suppose that is true in some parts of the country but around here I had a hard time even selling bare 727 cases. I have 5 or 6 big block cases that I tried to sell and people didn't want to pay much for them. Hard to get $100 for one since you can buy a complete trans for that on CL. (used and in unknown condition) Hardcore Mopar guys will want a new SFI case. I doubt the mfg will sell a ton of them but they'll sell enough to make money on the deal. The smart money would be on selling the case to other dealers such as ATI and the big trans shops rather than selling them retail. That lets everyone make some money.
[Re: moparx]
#2649379
04/26/19 05:47 PM
04/26/19 05:47 PM
Posts: 25,767 Rio Linda, CA
John_Kunkel
Rio Linda, CA
how can the case work with the 727 plus all the OD variants ? i thought where the OD bolted up, there are different hydraulic circuits, or are these blocked off somehow to allow this case to be used as a 727 ? If you look at the case where the valve body bolts up at the rear, the 3-speed and the OD are the same, depends on how the passages are routed into the tail from there.
[Re: John_Kunkel]
#2649418
04/26/19 08:52 PM
04/26/19 08:52 PM
Posts: 20,639 in a cattle trailer down by th...
Guitar Jones
It looks to me like it could be machined for either or, but not both.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2649778
04/28/19 08:46 AM
04/28/19 08:46 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I would take one when available...
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: DoubleD]
#2649821
04/28/19 10:57 AM
04/28/19 10:57 AM
Posts: 4,068 Mo.
racerx
Mo.
curios on the weight of these cases , compared to a stock case.
[Re: racerx]
#2649858
04/28/19 11:57 AM
04/28/19 11:57 AM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
If a guy already had a built 727, this is good insurance beefing up the case. IMO the thing I hate about my RMVB shift pattern is being stuck in 3rd with no handy neutral if something breaks. If that could be changed back to a normal pattern and keep the brake I might keep the 727. That adapter bell would make changing between a SB and BB easier also, as I would have to replace the case anyways to put a Gen 3 with it. Or get a glide for one.
[Re: Airwoofer]
#2649866
04/28/19 12:32 PM
04/28/19 12:32 PM
John_Kunkel
Rio Linda, CA
IMO the thing I hate about my RMVB shift pattern is being stuck in 3rd with no handy neutral if something breaks. "Clean Neutral" and "Safe Neutral" VB's have Neutral directly behind 3rd. Requires a shifter set up for them.
[Re: John_Kunkel]
#2649914
04/28/19 02:41 PM
04/28/19 02:41 PM
hemi-itis
IMO the thing I hate about my RMVB shift pattern is being stuck in 3rd with no handy neutral if something breaks. "Clean Neutral" and "Safe Neutral" VB's have Neutral directly behind 3rd. Requires a shifter set up for them. Me thinks I have clean Neutral when I press "N"
[Re: hemi-itis]
#2649990
04/28/19 08:05 PM
04/28/19 08:05 PM
Posts: 6,137 Melbourne , Australia
LA360
Best I can tell they've been developed for the diesel truck market. The bell housing mount pattern isn't the same as the ATI or Reid bells, they'll be offering their own bell housings as well. I know nothing about the particulars of Cummings diesels, I have no idea what the bell housing pattern is, so you might be waiting a while to see something that fits your SB or BB. Hopefully they offer something that takes the aftermarket bells we have already.
Alan Jones
[Re: hemi-itis]
#2650148
04/29/19 10:21 AM
04/29/19 10:21 AM
Posts: 19,380 north of coder
moparx
IMO the thing I hate about my RMVB shift pattern is being stuck in 3rd with no handy neutral if something breaks. "Clean Neutral" and "Safe Neutral" VB's have Neutral directly behind 3rd. Requires a shifter set up for them. Me thinks I have clean Neutral when I press "N" -itis, i wondered about that, and i think i may have even asked about it, but [as my mind always works - or doesn't ] i forget what the answer was, or is. mr. kunkle may have given me the answer. please refresh me sir. the pushbutton function - clean neutral. is it possible for the button to bypass 2nd and first fast enough from drive to effectively have a "clean neutral" ? TIA as always.
[Re: hemi-itis]
#2650210
04/29/19 01:14 PM
04/29/19 01:14 PM
John_Kunkel
Rio Linda, CA
IMO the thing I hate about my RMVB shift pattern is being stuck in 3rd with no handy neutral if something breaks. "Clean Neutral" and "Safe Neutral" VB's have Neutral directly behind 3rd. Requires a shifter set up for them. Me thinks I have clean Neutral when I press "N" The PB shifter moves the manual valve through 2 and 1 before arriving at N, same as any lever shifter.
