Re: shifter neutral switch wire
[Re: dragon]
#2647656
04/21/19 10:02 PM
04/21/19 10:02 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Use a solenoid that has a 4th pin that needs to be grounded to function - as opposed to one that's grounded through the case to what ever it's mounted to. Run that to the switch with the other side to a ground. Older stock Chrysler switches work that way.
[Re: hemi-itis]
#2647805
04/22/19 12:10 PM
04/22/19 12:10 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If you're using a stock Chrysler relay, the #2 wire is the one that runs through the neutral switch.. If you're using a Ford style solenoid, use the 4 pin style.that needs an external ground.
[Re: dragon]
#2647819
04/22/19 12:48 PM
04/22/19 12:48 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
What makes you think the switch in the shifter can't handle the starter solenoid load?
[Re: John_Kunkel]
#2647959
04/22/19 08:41 PM
04/22/19 08:41 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
What makes you think the switch in the shifter can't handle the starter solenoid load? Most of those switches are just small micro switches of some kind, I can't imagine they are intended to carry any substantial load. And most race cars are or should be running a remote Ford style solenoid to operate the starter, Or if it has factory stuff in it, run the brown wire in and interrupt it with the neutral switch.
[Re: CMcAllister]
#2648157
04/23/19 12:47 PM
04/23/19 12:47 PM
John_Kunkel
Rio Linda, CA
So, what's the current draw of a "Ford style solenoid"?
[Re: John_Kunkel]
#2648173
04/23/19 01:49 PM
04/23/19 01:49 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
So, what's the current draw of a "Ford style solenoid"? A Ford 4 pin solenoid can be used. I actually use a Cole-Hersee solenoid, this is a heavy-duty, all metal can unit designed for intermittent use. Wires just like the cheap plastic auto parts store Ford style unit. Has the 4th pin for grounding. Use a jumper on the starter and this solenoid carries the load of both the starter mounted solenoid and the starter motor. Main cable at the starter is only hot in "start". Current to engage this solenoid is just shy of 2.5A.
[Re: CMcAllister]
#2648200
04/23/19 03:51 PM
04/23/19 03:51 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
You do realize that the stock starting system uses a relay right? The current to activate the stock starter relay is very small. The micro switch that comes with the shifter is more than able to handle the current required to activate the stock relay.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: Digger73]
#2648216
04/23/19 04:43 PM
04/23/19 04:43 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Digger73 (Mike) Yes, I know how the stock system works. I'm assuming the OP isn't using the neutral switch in the transmission or he wouldn't have asked the question. And 3 days ago, I told him he could route the brown wire from the stock relay to the shifter switch and then to a handy ground IF he is using the stock stuff..
