Re: White Dart
[Re: WHITEDART]
#2648388
04/24/19 09:45 AM
04/24/19 09:45 AM
Posts: 4,067 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
That white dart is bad ass ...or bad to the bone I would like to ask this guy some specs on this ride this thing is impressive I need to build myself one of them .my hat is off to this dude thank you 4 your interest in the white dart... it is:15.5 to 1 . It was hot honed with a diamond hone. And torque plates.. tall deck block 340 Main 2.100 rod Journal.. Oliver steel rods..and a king 4in stroke crank .55mm cam . A set of Brett Miller Big w8s . 420 intake by Brett Miller.and a .2.500 . Bob book dominator. ATI Powerglide Ford 9-inch leaf springs and up front coilovers mounted in the factory shock location... Have you had it on the dyno? What do you figure it is making for power?
Re: White Dart
[Re: HardcoreB]
#2648394
04/24/19 10:00 AM
04/24/19 10:00 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
That white dart is bad ass ...or bad to the bone I would like to ask this guy some specs on this ride this thing is impressive I need to build myself one of them .my hat is off to this dude thank you 4 your interest in the white dart... it is:15.5 to 1 . It was hot honed with a diamond hone. And torque plates.. tall deck block 340 Main 2.100 rod Journal.. Oliver steel rods..and a king 4in stroke crank .55mm cam . A set of Brett Miller Big w8s . 420 intake by Brett Miller.and a .2.500 . Bob book dominator. ATI Powerglide Ford 9-inch leaf springs and up front coilovers mounted in the factory shock location... Have you had it on the dyno? What do you figure it is making for power? . At the crank 960 ish . According to Wallace 951 still have work to do for sure...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: White Dart
[Re: WHITEDART]
#2648449
04/24/19 12:44 PM
04/24/19 12:44 PM
HardcoreB
Shelby Twp. Mi
....still have work to do for sure... I wouldn't put it that way, you're already using a larger percentage of your power than most people. Nice work. I didn't notice your best 1/8 MPH? Any plans to use the new intake Brett is casting?
Re: White Dart
[Re: HardcoreB]
#2648451
04/24/19 12:49 PM
04/24/19 12:49 PM
WHITEDART
bean town ....Ca
....still have work to do for sure... I wouldn't put it that way, you're already using a larger percentage of your power than most people. Nice work. I didn't notice your best 1/8 MPH? Any plans to use the new intake Brett is casting? . We ordered one for the new bullet this engine will stay together as a complete working unit the new motor will be slightly smaller with a set of his monster w8s . And new intake I have been Gathering parts and pieces for a couple years
Re: White Dart
[Re: HardcoreB]
#2648646
04/24/19 10:13 PM
04/24/19 10:13 PM
WHITEDART
bean town ....Ca
....still have work to do for sure... I wouldn't put it that way, you're already using a larger percentage of your power than most people. Nice work. I didn't notice your best 1/8 MPH? Any plans to use the new intake Brett is casting? 129.84
Re: White Dart
[Re: WHITEDART]
#2650418
04/30/19 04:53 AM
04/30/19 04:53 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
I've removed the spare tire well and installed a flat sheet metal I've removed the inner Fender Wells.. it maintains stock doors fenders and floor. It has fiberglass bumpers hood and decklid.. and most recently I added a carbon fiber Dash... that we use the MSD grid for the ignition.. and a sportsman racepak and IQ 3 for the dash.. Very fast car and work's well congrats.What did the race weight end up being after you lightened it.
Re: White Dart
[Re: Ian]
#2650483
04/30/19 10:51 AM
04/30/19 10:51 AM
WHITEDART
bean town ....Ca
I've removed the spare tire well and installed a flat sheet metal I've removed the inner Fender Wells.. it maintains stock doors fenders and floor. It has fiberglass bumpers hood and decklid.. and most recently I added a carbon fiber Dash... that we use the MSD grid for the ignition.. and a sportsman racepak and IQ 3 for the dash.. Very fast car and work's well congrats.What did the race weight end up being after you lightened it. 2800lbs . Unless were on a greasy track like this weekend we ended up with 75 lb a ballast trying to make the car leave the starting line...
Re: White Dart
[Re: fullmetaljacket]
#2650519
04/30/19 12:29 PM
04/30/19 12:29 PM
WHITEDART
bean town ....Ca
Added ballast is a friend to traction and dead vehicle weight is a foe to within a fraction. well said
