Re: 15 X 8 Ramcharger steel wheel. Backspacing?
[Re: 340SIX]
#2647891
04/22/19 05:07 PM
04/22/19 05:07 PM
Posts: 10,132 A Red State
SNK-EYZ
A Red State
15 x 8" Ramcharger wheel backspacing is 4". The ones I have here are 4.25" It depends on where you're measuring. From the axle mounting flange to the very outer lip of the wheel is 4.25 inches. If you measure to outside the bead seat area it's 4 inches. (the lip sticks out 1/4 inch).
[Re: duster2]
#2648019
04/22/19 11:25 PM
04/22/19 11:25 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Everyone of the 550 Ramcharger wheels , that I have ever measured are 4.25 backspace. Frank Same here and that is what is on this !
[Re: moparx]
#2648205
04/23/19 04:04 PM
04/23/19 04:04 PM
Posts: 28,596 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
i believe the real reason there is confusion, is different wheel manufacturers either measure to the bead seat[which i personally believe to be the correct way, as that positions the tire], while others measure to the outermost portion of the wheel lip. as all lips are not created equal [take that comment however you want ! ] this would account on discrepancies in backspace dimensions. with that being said, Ramcharger wheels are either 4" or 4 1/4" backspace. your choice. My son worked at a Rim Place that rebuilt wheels. They put new centers on or new hoops whatever is needed. Also has a CNC Lathe to resurface Aluminum. He checked them for being straight and what not. Blasted and Re-Painted. They said they were 4.25" Backspace to the Lips. That is how I have done them too. But there is more than one way to skin a cat I guess
