Unilug Indy Slots
#2647316
04/20/19 04:53 PM
04/20/19 04:53 PM
Posts: 16,160 Mesa, Arizona
dart4forte
Mesa, Arizona
Bought a set of 15x9 Indy slots. They are unilug so Im in search for vendor that sells them. Anyone know of a source. Tried Summit but they need a part number off the wheel. Cleaned both wheels up and no part number to be found
Abe Lincoln
Re: Undiluted for Indy Slots
[Re: fourgearsavoy]
#2647331
04/20/19 05:41 PM
04/20/19 05:41 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I was wondering about that too. The center section looks odd to me too. Figured maybe the picture was distorted, just like the word uni-lug was undiluted. Cell phone type thing.
I have mechanical Aptitude. I can screw up anything.
[Re: dvw]
#2647474
04/21/19 08:07 AM
04/21/19 08:07 AM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
The aftermarket wheels that came on my 70 D100 have slotted lug holes on a flat surface. They used shank style lug nuts without oval washers.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: dvw]
#2647511
04/21/19 10:32 AM
04/21/19 10:32 AM
dart4forte
Mesa, Arizona
I worked in the tire and wheel business in the mid 70's. There was an Ansen knockoff wheel that had oval slots for the lugs. It used standard shank type lugs and washers, not Uni-lug. If the lug holes are nicely formed ovals from the center outward these are the ones. Ansen Sprint II used round Uni-lug washers and were polished. ET IV used oval Uni-lug washers and were polished. Ansen Sprint I and Fenton were not Uni- lug, and machine finished. What brand is cast into the back of the wheel. My bet is they are 8 1/2" wide. Measure between the beads, not outside. Doug I’ve cleaned and scuffled the back of the wheels and can’t find either the brand or part number. The stamping on the back of the wheels are 15x8.5.
Abe Lincoln
[Re: dart4forte]
#2647513
04/21/19 10:45 AM
04/21/19 10:45 AM
bboogieart
Lost and Spaced
Can you supply a better picture? The wheel does not look round. The center looks oval as well. The bolt holes, 3 look oval and two look round. They also appear to be wallowed out, as mentioned. If so, the point is moot. They would be junk.
[Re: dvw]
#2647525
04/21/19 11:41 AM
04/21/19 11:41 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I worked in the tire and wheel business in the mid 70's. There was an Ansen knockoff wheel that had oval slots for the lugs. It used standard shank type lugs and washers, not Uni-lug. If the lug holes are nicely formed ovals from the center outward these are the ones. Ansen Sprint II used round Uni-lug washers and were polished. ET IV used oval Uni-lug washers and were polished. Ansen Sprint I and Fenton were not Uni- lug, and machine finished. What brand is cast into the back of the wheel. My bet is they are 8 1/2" wide. Measure between the beads, not outside. Doug Agreed, standard hub centric aftermarket rims with either 4.5-4.75 BC or 4.75-5.00 BC oval slots, OP needs shank type lugs and washers not uni lug OP might even need hub centric adapter rings depending on the center bore? Mike
[Re: TJP]
#2647577
04/21/19 02:59 PM
04/21/19 02:59 PM
dart4forte
Mesa, Arizona
Yes, they are hub centric. Here’s another view
I have two other wheels just like this pair.
Abe Lincoln
[Re: dart4forte]
#2647608
04/21/19 06:57 PM
04/21/19 06:57 PM
bboogieart
Lost and Spaced
WOW looks like some one went at them with a rat tail file. Me, I wouldn't use 'em. Sorry.
[Re: bboogieart]
#2647621
04/21/19 07:50 PM
04/21/19 07:50 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
Actually, it’s pretty obvious what happened is someone used conical lug nuts on the wheels instead of mag style.
I would just use the correct nuts now, they’ll be fine as far as the damage.
[Re: Pacnorthcuda]
#2647631
04/21/19 08:41 PM
04/21/19 08:41 PM
Posts: 9,865 MI, usa
dvw
MI, usa
I would just use the correct nuts now, they’ll be fine as far as the damage. WOW looks like some one went at them with a rat tail file. Me, I wouldn't use 'em. Sorry. [/quote] I don't think so. It looks like the wheels were used on a 4 /2" bolt circle. Therefore the washers would have only come to the outside of the oval hole. The telling tail would be a picture from the back side and see if the lug holes were truly machined into an oval shape. Doug
[Re: Pacnorthcuda]
#2647662
04/21/19 10:28 PM
04/21/19 10:28 PM
Posts: 18,157 Mass
DAYCLONA
Mass
I agree that the backside would tell. To me, on my ipad, they look like a unilug oval. I’m not a fan, but if that’s the case then the damage on the other side doesn’t add to the issue once mag lugs and washers are used.
If however they are NOT unilug, then they are damaged beyond use. Being hub centric, the center hub positions the wheel, not the lugs, so the wheel is not "damaged beyond use" if the correct lugs and washers are used, even if the lug holes were "ovaled" out from improper prior hardware ....
