Unilug Indy Slots #2647316
04/20/19 04:53 PM
04/20/19 04:53 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Bought a set of 15x9 Indy slots. They are unilug so Im in search for vendor that sells them. Anyone know of a source. Tried Summit but they need a part number off the wheel. Cleaned both wheels up and no part number to be found
Abe Lincoln
Re: Undiluted for Indy Slots [Re: dart4forte] #2647322
04/20/19 05:12 PM
04/20/19 05:12 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
What does undiluted mean, spell check error?
I ordered mine from Summit in their online catalog.
Here's what I have on my keystones.
Washers;
https://www.summitracing.com/parts/gor-79905c
Lug nuts need 5 sets of 4
https://www.summitracing.com/parts/rnb-711-208
I have mechanical Aptitude.
I can screw up anything.
Re: Undiluted for Indy Slots [Re: bboogieart] #2647326
04/20/19 05:32 PM
04/20/19 05:32 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Those don't look like factory made uni-lug wheels to me. The ones I have seen have a spot face machined for the oval washers under the nuts twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Undiluted for Indy Slots [Re: fourgearsavoy] #2647331
04/20/19 05:41 PM
04/20/19 05:41 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I was wondering about that too.
The center section looks odd to me too.
Figured maybe the picture was distorted, just like the word uni-lug was undiluted.
Cell phone type thing. shruggy
Re: Undiluted for Indy Slots [Re: bboogieart] #2647342
04/20/19 06:17 PM
04/20/19 06:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What you have are not unilug. They just look wallowed out. . https://www.ebay.com/itm/vintage-sl...-rod-Hot-Gasser-Ford-Chevy/202649910082?
Re: Undiluted for Indy Slots [Re: stumpy] #2647399
04/20/19 09:17 PM
04/20/19 09:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
That wheel looks like someone took a Mopar/Ford 4.5 pattern out to GM 4.75, which also uses 7/16" instead of 1/2" studs; looks to me like the modified ID is smaller than the original.
Re: Undiluted for Indy Slots [Re: topside] #2647427
04/20/19 11:53 PM
04/20/19 11:53 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
I agree with Stumpy
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Undiluted for Indy Slots [Re: BloFish] #2647471
04/21/19 07:40 AM
04/21/19 07:40 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I worked in the tire and wheel business in the mid 70's. There was an Ansen knockoff wheel that had oval slots for the lugs. It used standard shank type lugs and washers, not Uni-lug. If the lug holes are nicely formed ovals from the center outward these are the ones. Ansen Sprint II used round Uni-lug washers and were polished. ET IV used oval Uni-lug washers and were polished. Ansen Sprint I and Fenton were not Uni- lug, and machine finished. What brand is cast into the back of the wheel. My bet is they are 8 1/2" wide. Measure between the beads, not outside.
Doug
Re: Undiluted for Indy Slots [Re: dvw] #2647474
04/21/19 08:07 AM
04/21/19 08:07 AM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
The aftermarket wheels that came on my 70 D100 have slotted lug holes on a flat surface. They used shank style lug nuts without oval washers.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Undiluted for Indy Slots [Re: dvw] #2647511
04/21/19 10:32 AM
04/21/19 10:32 AM
Mesa, Arizona
Mesa, Arizona
Doug
I’ve cleaned and scuffled the back of the wheels and can’t find either the brand or part number. The stamping on the back of the wheels are 15x8.5.
Abe Lincoln
Re: Undiluted for Indy Slots [Re: dart4forte] #2647513
04/21/19 10:45 AM
04/21/19 10:45 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Can you supply a better picture?
The wheel does not look round.
The center looks oval as well.
The bolt holes, 3 look oval and two look round.
They also appear to be wallowed out, as mentioned.
If so, the point is moot. They would be junk.
Re: Undiluted for Indy Slots [Re: dvw] #2647525
04/21/19 11:41 AM
04/21/19 11:41 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Doug
Agreed, standard hub centric aftermarket rims with either 4.5-4.75 BC or 4.75-5.00 BC oval slots, OP needs shank type lugs and washers not uni lug
OP might even need hub centric adapter rings depending on the center bore?
Mike
Re: Undiluted for Indy Slots [Re: BloFish] #2647530
04/21/19 11:52 AM
04/21/19 11:52 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by BloFish
I agree with Stumpy
iagree x3
Re: Undiluted for Indy Slots [Re: TJP] #2647577
04/21/19 02:59 PM
04/21/19 02:59 PM
Mesa, Arizona
Mesa, Arizona
Yes, they are hub centric. Here’s another view
I have two other wheels just like this pair.
Abe Lincoln
Re: Undiluted for Indy Slots [Re: dart4forte] #2647608
04/21/19 06:57 PM
04/21/19 06:57 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
WOW looks like some one went at them with a rat tail file.
Me, I wouldn't use 'em. Sorry. shruggy
Re: Undiluted for Indy Slots [Re: bboogieart] #2647621
04/21/19 07:50 PM
04/21/19 07:50 PM
Kirkland, Washington
Pacnorthcuda Offline
Actually, it’s pretty obvious what happened is someone used conical lug nuts on the wheels instead of mag style.
I would just use the correct nuts now, they’ll be fine as far as the damage.
Re: Undiluted for Indy Slots [Re: bboogieart] #2647624
04/21/19 08:09 PM
04/21/19 08:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Nor would I twocents beer
Re: Undiluted for Indy Slots [Re: Pacnorthcuda] #2647631
04/21/19 08:41 PM
04/21/19 08:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Me, I wouldn't use 'em. Sorry. [/quote]
I don't think so. It looks like the wheels were used on a 4 /2" bolt circle. Therefore the washers would have only come to the outside of the oval hole. The telling tail would be a picture from the back side and see if the lug holes were truly machined into an oval shape.
Doug
Re: Undiluted for Indy Slots [Re: dvw] #2647636
04/21/19 09:16 PM
04/21/19 09:16 PM
I agree that the backside would tell. To me, on my ipad, they look like a unilug oval. I’m not a fan, but if that’s the case then the damage on the other side doesn’t add to the issue once mag lugs and washers are used.
If however they are NOT unilug, then they are damaged beyond use.
Re: Undiluted for Indy Slots [Re: Pacnorthcuda] #2647662
04/21/19 10:28 PM
04/21/19 10:28 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Being hub centric, the center hub positions the wheel, not the lugs, so the wheel is not "damaged beyond use" if the correct lugs and washers are used, even if the lug holes were "ovaled" out from improper prior hardware ....
