EFI? #2647194
04/20/19 11:17 AM
04/20/19 11:17 AM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
For the guys running EFI with Procharger or turbo what brand elbow and throttle body are you running with a 4500 flange intake?
Thanks for any and all info
Kevin
Re: EFI? [Re: 604 Hemi GTX] #2647215
04/20/19 12:01 PM
04/20/19 12:01 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Or ROOTS!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: EFI? [Re: hemi-itis] #2647216
04/20/19 12:05 PM
04/20/19 12:05 PM
Originally Posted by hemi-itis
Or ROOTS!!
Why would you run a elbow on a throttle body on top of the blower? confused
Re: EFI? [Re: Cab_Burge] #2647217
04/20/19 12:08 PM
04/20/19 12:08 PM
hemi-itis Offline
hemi-itis  Offline
Or ROOTS!!
LMOL! I have been thinking alot about EFI,,,,, blush
Re: EFI? [Re: hemi-itis] #2647467
04/21/19 07:10 AM
04/21/19 07:10 AM
pa
572charger Offline
572charger  Offline
pa
i have a indy mod man hemi intake with 160lb injectors and rails we are making a custom top for it and a wilson 105 mm throttle body i have a procharger f-2 set up for it
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: EFI? [Re: 604 Hemi GTX] #2647488
04/21/19 09:07 AM
04/21/19 09:07 AM
in front of the computer
8
80arrow Offline
80arrow  Offline
I ran a Wilson 105 TB on my Procharged small block. Going to use it again with a turbo small block. I used a elbow from 6061.com, awesome quality and he would make what ever you needed and add ports if you wanted.
Re: EFI? [Re: 80arrow] #2647589
04/21/19 04:57 PM
04/21/19 04:57 PM
ONTARIO,CANADA
ONTARIO,CANADA
Ok good to know I saw a few cars with the burst panel on the elbow but couldn’t find them on line.
I’ll get a hold of 6061.com and get one made
Kevin
Re: EFI? [Re: 604 Hemi GTX] #2648488
04/24/19 02:50 PM
04/24/19 02:50 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
I've had pretty good luck with the cast Edelbrock elbows with a 105mm throttle body. They are priced very reasonably. They make several versions. IF you can fit the big one, your engine will like the extra plenum area.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
