Re: White Dart
[Re: DavidDean]
#2647602
04/21/19 06:41 PM
04/21/19 06:41 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Is that a Ritter block ? Do additionally oil at the china wall ? Keep on Rockin ! . David thank you yes it is and we oil 100% through the China wall...
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: White Dart
[Re: WHITEDART]
#2647603
04/21/19 06:43 PM
04/21/19 06:43 PM
WHITEDART
bean town ....Ca
4 gallon fuel cell quick fuel 427 pump.. anti-gravity lithium 12 volt and a 16 volt step up for the fuel pump...
Re: White Dart
[Re: cesar perez]
#2647667
04/21/19 10:52 PM
04/21/19 10:52 PM
WHITEDART
bean town ....Ca
What type of front suspension you have in there? Mustang 2 . the k-member and lower control arms.. were engineered and designed.. by Rod McGregor AKA just a dart.. it has virtually no bump steer which greatly enhance the ET of the car... the wheels stay extremely stable when coming down from a wheelie.... it uses menscer coilovers mounted in the Factory shock location...
Re: White Dart
[Re: n20mstr]
#2647859
04/22/19 03:24 PM
04/22/19 03:24 PM
WHITEDART
bean town ....Ca
I SEE SOME FIBERGLASS DOORS IN YOUR FUTURE....
CAR IS SO BAD A$$
NO POWER ADDER EITHER !!!!
thanks.. I've been fighting the urge for some glass doors seems as though that's what everybody else has.. at some point I'm afraid that's the direction it will go
Re: White Dart
[Re: fullmetaljacket]
#2647926
04/22/19 07:05 PM
04/22/19 07:05 PM
WHITEDART
bean town ....Ca
Send your existing doors to my man "Kulasa the Dipper" in Detroit and he'll make em' featherweight and you can still boast that you have an all steel body. He can take weight off in designated areas so that areas that are meant to keep the strength ( Hinge mount panel, door striker panel) can stay that way.
You would have to paint them again though. Keep the Bows and Fodes scratching their heads. LOL.
Wish you were in my part of town and at sometime (because I'm busy) we could get that pup down to 2700 Lbs. .. interesting concept on the door lightning program.. I think I will have to explore that idea further..
Re: White Dart
[Re: WHITEDART]
#2648029
04/22/19 11:46 PM
04/22/19 11:46 PM
Posts: 263 CA, USA
JcodeCharger
CA, USA
Will you be going to the next Match Race Madness? I guess I will be racing Kevin at that one.
68 twin turbo Dart 8.19 so far 70 Swinger 360 69 Roadrunner 383 4 speed 69 Mod Top Satellite 383 auto 69.5 A12 Super Bee 4 speed 70 T/A Challenger 70 FC7 Duster 340 4 speed 70 FJ5 Superbird 68 Hemi 4 speed Roadrunner 71 Duster W2 340
Re: White Dart
[Re: JcodeCharger]
#2648041
04/23/19 12:08 AM
04/23/19 12:08 AM
WHITEDART
bean town ....Ca
Will you be going to the next Match Race Madness? I guess I will be racing Kevin at that one. .. yes we will be running N/A 10.5.. hopefully we can do well at representing mother Mopar against all the bandits...
Re: White Dart
[Re: WHITEDART]
#2648057
04/23/19 07:25 AM
04/23/19 07:25 AM
Posts: 4,702 On the parachute mount
n20mstr
CAR IS SO BAD A$$
thanks.. I've been fighting the urge for some glass doors seems as though that's what everybody else has.. at some point I'm afraid that's the direction it will go it will lose you 100 or more pounds
....BAD A$$ STREET CAR.....
Re: White Dart
[Re: WHITEDART]
#2648091
04/23/19 09:59 AM
04/23/19 09:59 AM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Will you be going to the next Match Race Madness? I guess I will be racing Kevin at that one. .. yes we will be running N/A 10.5.. hopefully we can do well at representing mother Mopar against all the bandits... What 1st gear are you running and what rear end gear? I have a similar package.
Re: White Dart
[Re: WHITEDART]
#2648147
04/23/19 12:35 PM
04/23/19 12:35 PM
Posts: 43,360 Bend,OR USA
Cab_Burge
Wish you were in my part of town and at sometime (because I'm busy) we could get that pup down to 2700 Lbs. .. interesting concept on the door lightning program.. I think I will have to explore that idea further.. Aero Chem in El Mirage may be your friend on this, if there still in business
Re: White Dart
[Re: Sammy]
#2648159
04/23/19 12:59 PM
04/23/19 12:59 PM
WHITEDART
bean town ....Ca
Will you be going to the next Match Race Madness? I guess I will be racing Kevin at that one. .. yes we will be running N/A 10.5.. hopefully we can do well at representing mother Mopar against all the bandits... What 1st gear are you running and what rear end gear? I have a similar package. . 1 87 first . The rear gear changes depending on what track we' are racing.. not really satisfied with the first gear ratio to be honest..
Re: White Dart
[Re: Bigcube]
#2648168
04/23/19 01:32 PM
04/23/19 01:32 PM
WHITEDART
bean town ....Ca
[quote=Bigcube]Nice car, runs great! [/quote . Thank you sir
Re: White Dart
[Re: WHITEDART]
#2648170
04/23/19 01:34 PM
04/23/19 01:34 PM
n20mstr
Will you be going to the next Match Race Madness? I guess I will be racing Kevin at that one. .. yes we will be running N/A 10.5.. hopefully we can do well at representing mother Mopar against all the bandits... What 1st gear are you running and what rear end gear? I have a similar package. . 1 87 first . The rear gear changes depending on what track we' are racing.. not really satisfied with the first gear ratio to be honest.. You have a RACEPAK, this is a big thing to get the converter, the SLR and the rear gear all on the same page. Best thing is to get the RACEPAK data in front of people that know what and how all these things relate to and effect each other. You have wheelie bars, but honestly im sure you know that the car will be quicker if they don't ever touch the track surface. I don't know who you rely on for tuning info, and as far as NA goes there are not TOO many guys . BUT there are a ton of turbo,nitrous guys that race small tire cars and can help you . Obviously the easiest thing to change is the rear gear, as far as the converter you may get recommendations to get a bolt together so you can be changing stators, or just change fluids from dex4 to type F or hyd fluid. Just rambling on....
