78 amp alternator upgrade issue #2646289
04/17/19 11:59 PM
04/17/19 11:59 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
My 40 amp alternator in my dart took a dump last night. I figured since I've added injection and electronic ignition, I would upgrade to the 78 amp alternator and the newer style voltage regulator. I do have the injection system, electronic ignition, and headlight system attached to the back of the alternator. I did add in the second field wire. Now my ammeter is pegged to the charging side, but the battery is only getting 12.8 volts. What could cause this? I do have another voltage regulator I could try. Could the field wires be plugged in wrong? Electrical is not my strong suit. Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 78 amp alternator upgrade issue [Re: GTSDart340] #2646307
04/18/19 01:57 AM
04/18/19 01:57 AM
Do you know what the amp rating is on your amp meter? Is the 78 amp alternator a newer Mopar replacement factory type or a after market one?
If Mopar type try reading the voltage at the output side of the alternator on the big wire going back to the battery with the motor revved up above 2500 RPM and see if the voltage output increases scope Is the alternator belt real tight or not? If not tight, tighten it up so it is wrenchtwocents
Let us know what you find up
Re: 78 amp alternator upgrade issue [Re: Cab_Burge] #2646314
04/18/19 03:57 AM
04/18/19 03:57 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
1st... don't worry about the ammeter capacity anymore. Your ammeter will be safe with high output alts since won't read anymore power coming and going from batt because wont be discharged like previouslly did. The stock 78 amps mopar alt is still not the MOST efficient of all but WAY BETTER than the old stock one ( is the one I'm using ) specially with the small pulley they use to come. Ammeter reads what the batt sucks and provides, not what the alt sources,
Now, about the voltage... not everything is on alternator, but on wiring conditions. Did you JUST upgraded the alt without consider the wiring and ALSO ammeter conditions itself? After all these years of abuse over a not correct charging plattform from factory lot of stuff can be affected
Charging system upgrade
Alt fields can be connected in either way, so don't worry about that.
Reg must be good grounded.
Re: 78 amp alternator upgrade issue [Re: NachoRT74] #2646383
04/18/19 09:08 AM
04/18/19 09:08 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
What's the voltage at the alternator terminal stud?
If the alternator is full fielded (max output all the time) then idds are the green wire is grounded, or your regulator is bad.
Don't be the exception.
Re: 78 amp alternator upgrade issue [Re: Supercuda] #2646392
04/18/19 09:41 AM
04/18/19 09:41 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Don't newer alternators have the voltage regulator built in ??
Re: 78 amp alternator upgrade issue [Re: Stanton] #2646426
04/18/19 11:02 AM
04/18/19 11:02 AM
No stock Mopars that I know of shruggy
You can buy high output after market single wire and use them also work
I did on my current S/P bracket car, Powermaster 100 amp single wire up
Re: 78 amp alternator upgrade issue [Re: Cab_Burge] #2646516
04/18/19 04:07 PM
04/18/19 04:07 PM
Laveen, Arizona
Laveen, Arizona
I did use the factory 78 amp alternator, and in going to run the ammeter bypass tonight. I started the car this morning to check the voltage at the back of the alternator, and it was showing 15 volts there. I checked the battery, and it was showing 13.5. I didn't change anything from last night to this morning. Any thoughts on what to check?
Re: 78 amp alternator upgrade issue [Re: GTSDart340] #2646523
04/18/19 04:29 PM
04/18/19 04:29 PM
Andrewh Online content
Andrewh  Online Content
so you converted a 68 single field charging system to the dual field charging system for the 78 amp alt.
one field wire from the new vr, the second field wire from the key on 12 volt power that went to the original VR. with a split to the new vr for sensing.
you need to verify sensing voltage first. Be sure you use the same reference ground.
Battery pos to battery neg on the meter for battery voltage.
sensing line to case of the VR for sensing line voltage. Do not use the battery ground or you may get a false reading.
Alt from the back post to the alt case.
I have had charging issues because of 3 things.
the new connector is bad for the sensing voltage line. causing intermittent over charge conditions.
The sensing voltage has dropped too much passing through the bulkhead 3 times. you can clean the bulkhead connector, or use a relay to give power directly from the battery.
The VR was not grounded properly. I always add a ground cable to the bolt holding the vr to the firewall.
15 volts at the back of the alt is a bit high, but 13.5 at the battery is fine.
amp meter might have issues, your battery could be low and is charging to compensate.
or you are actually over charging and don't know it.
Re: 78 amp alternator upgrade issue [Re: GTSDart340] #2646524
04/18/19 04:29 PM
04/18/19 04:29 PM
If your seeing 15 volts at the alternator stud or on the output wire and only 13.0 volts at the battery you have a bad connection( high resistance, corrosion or loose) somewhere between the two scope Two volts drop between the two is way to much tsk
take your volt meter and trace it back from the alternator to the bulkhead connector and then back on the other wire that feeds to the battery scope If your seeing 14+ volts into the bulkhead connector and less than than 14.0 volts coming out your on the way to fixing it grin
I have seen more than one Mopar, 1966 to 1971 model yrs. have the inner nut on the amp gauge loose causing what you may have now work scope
Please let us know what you find so others on here can benefit from your work also up
What year, make and model car are you working on?
Hopefully someone on here will have the correct year and model factory service manual (FSM) so they can look up the wiring schematic and tell you which wire color and pin location to test from luck
Re: 78 amp alternator upgrade issue [Re: Andrewh] #2646659
04/18/19 11:34 PM
04/18/19 11:34 PM
Laveen, Arizona
Laveen, Arizona
It appears the sensor wire is getting an incorrect reading. At idle the battery voltage shows 13 ish volts, the sensor wire shows 11.5. I have read about putting a relay in to correct the sensor wire issue. Does anyone have a wiring diagram for that? How difficult would that be? I have limited use of my arms, so I'd prefer not to have to tinker under the dash. Thanks!
Re: 78 amp alternator upgrade issue [Re: GTSDart340] #2646803
04/19/19 11:38 AM
04/19/19 11:38 AM
I put mine under the hood.
the sensing line comes out from the bulkhead and you tapped it for the extra line and the VR.
Just before that split, I cut it and wired in the relay.
Used the original sensing line to trip the relay, grounded at the body, for the other leg ran a new hot from the battery to the relay for power.
Re: 78 amp alternator upgrade issue [Re: Andrewh] #2646806
04/19/19 11:46 AM
04/19/19 11:46 AM
Laveen, Arizona
Laveen, Arizona
That's exactly what I was thinking, but wanted to verify before I did it. Fires suck! Thanks for your help!
Re: 78 amp alternator upgrade issue [Re: GTSDart340] #2647164
04/20/19 10:15 AM
04/20/19 10:15 AM
As said recheck how you have everything wired & I would temp wire it all up with jumpers & confirm everything is copacetic on your readings then hard wire everything. A relay is good but as you know there is an issue elsewhere that needs to be addressed first.
Re: 78 amp alternator upgrade issue [Re: GTSDart340] #2647214
04/20/19 12:01 PM
04/20/19 12:01 PM
Have you look at a FSM wiring schematic yet ? If not look at one so you know about which wires feed the field on your alterantor scope
One is from the ignition switch and the other is from the ignition ballast resistor which is fed from the ignition switch work
If you don't want melted wires find out what is ( loose wires, bad connection, corrosion)causing the voltage drop between the dash and engine wiring harnesses and fix it ! scope wrench
I've had to fix a bunch of burnt up wiring harness in many Mopar cars I've owned, the factory wiring and assembly of those cars suck rantwhiney shruggy
The old cars, pre OTB-1, have very simple circuits, no magic in them at all, battery and ground only except inside the alternators grin
Re: 78 amp alternator upgrade issue [Re: Cab_Burge] #2647449
04/21/19 01:34 AM
04/21/19 01:34 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Hopefully you have it fixed. If not I agree with Cab about a voltage drop problem. If it still has problems I would do a charging system output voltage drop test next. Good luck with it. Ron
Re: 78 amp alternator upgrade issue [Re: 383man] #2647469
04/21/19 07:37 AM
04/21/19 07:37 AM
Valencia, España
Valencia, España
Deleted
Re: 78 amp alternator upgrade issue [Re: GTSDart340] #2647529
04/21/19 11:49 AM
04/21/19 11:49 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
If there is nothing on the battery circuit other than the battery, then there is a big problem in the wiring between the ammeter and the battery.
Recharging of the battery should never be drawing 40 amps (gage pegged).
30 amps for a few seconds is OK right after starting,
5 amps for a few minutes.
Once recharged it should show zero.
Over 30 amps for anything more than a 1/2 minute and the weakest connections will get hot and then fail.
If the positive field wire is at 12.8 volts and the alternator output is at 14 Volts then there is a bad connection or wire as the others have already posted.
Re: 78 amp alternator upgrade issue [Re: Mattax] #2647539
04/21/19 12:17 PM
04/21/19 12:17 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
You'll have to make your own diagram, but this should give you a start.
Its a schematic for 67-9 A-body with the mentioned mods wired in as guesses about the connections.
On the 70 up voltage regulator, the sensing wire must be the same as the power feed. The green wire connection is the ground side and the regulator controls hpow frequently to complete the circuit to ground. According to the MTSC, they attach as shown in the triangle. I don't have one in hand to confirm that.
Re: 78 amp alternator upgrade issue [Re: Mattax] #2647542
04/21/19 12:25 PM
04/21/19 12:25 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Notice the ammeter only shows current flowing to or from the battery.
Pegging it either direction indicates a big problem.
Because you have EFI and pumps to support it, discharge during start will be higher than a normal car and rechanrging after start will be proportionally higher as well. How much draw from the EFI and pump should be in the documentation.
Adding a parallel wire from the alternator output to the ammeter's positive post will reduce the load on the bulkhead connection both during start and during recharge.
Another paralel wire from the fusible link to the ammeter bat terminal wouldn't hurt if you can make a good crimp at the link.
Re: 78 amp alternator upgrade issue [Re: Mattax] #2647549
04/21/19 12:49 PM
04/21/19 12:49 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Remember, the ONLY ammeter load on the battery side of the ammeter is supposed to be the battery. Nothing else. I fyou have anythign else there it will show up as a discharge on the ammeter.
