1969 Superbee Neutral Starting Switch #2646767
04/19/19 10:46 AM
04/19/19 10:46 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Good Morning Everyone,
Does anyone have a diagram of how the neutral starting switch and reverse lights are
run for a 1969 Superbee 383 w/ a 4 Speed manual transmission?
Thanks!!
Re: 1969 Superbee Neutral Starting Switch [Re: jim6346] #2646810
04/19/19 12:02 PM
04/19/19 12:02 PM
moparx Offline
moparx  Offline
i believe you only have a reverse light switch on the transmission. it completes the ground for the backup light circuit.
1970, i believe, was the first year for the clutch safety switch, wherin the clutch needed to be depressed [completing the ground circuit for the starter relay] before the starter would/could be engaged.
beer
Re: 1969 Superbee Neutral Starting Switch [Re: moparx] #2646853
04/19/19 02:11 PM
04/19/19 02:11 PM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
I think you mean the reverse light on the lower dash.
Sorry no diagrams.
KID
Re: 1969 Superbee Neutral Starting Switch [Re: Kidsixpack] #2646858
04/19/19 02:16 PM
04/19/19 02:16 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Hi,
Thanks for the responses.
What goes to the starter solenoid? Can't get it to turn over, so I just assumed
it was missing? Is it bypassed somehow?
This is my first 4 speed, used to dealing with automatics.
Thanks,
Re: 1969 Superbee Neutral Starting Switch [Re: jim6346] #2646864
04/19/19 02:27 PM
04/19/19 02:27 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The stick needs the starter relay to be the self grounding style(for stick cars) or a wire from the ground terminal to a ground if you have the automatic trans relay.
Re: 1969 Superbee Neutral Starting Switch [Re: jim6346] #2646866
04/19/19 02:49 PM
04/19/19 02:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '69 stickshift relay has one corner grounded instead of a spade terminal, '70-later used a clutch pedal safety switch.
Re: 1969 Superbee Neutral Starting Switch [Re: John_Kunkel] #2646877
04/19/19 03:34 PM
04/19/19 03:34 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Ahhh, that explains it!! Found the right one at NAPA. Thanks everyone and have a Happy Easter!!
Re: 1969 Superbee Neutral Starting Switch [Re: jim6346] #2646932
04/19/19 06:51 PM
04/19/19 06:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FWIW, on the earlier cars, most auto parts stores only have the AT starter solenoid. In that case, fab a ground wire from the bottom left lug to one of the mounting screws, and it'll work.
I found a MT solenoid at VansAutoLLC.
Another thing you can do - I had an earlier thread on this - is use the AT solenoid with the ground wired to a hidden switch as a theft preventative.
