A little update. Frame is now shorter thanks to my dad (poorboy)! Yesterday I started to disassemble the r.c. got the dash out, removed the windshield, and started taking the grill out after work. Tomorrow after work I am hoping to get most of the front clip off. I did some more research in gas tank situation. A tank out of a 05-07 caravan looks close. The pump will be sufficient to run the hemi. Just need to get real measurements of the physical size. I found out tonight when I called the junkyard there were two different sizes because of stow and go seats so I have to look into that. It's kind of difficult to research because everything just confirms it will fit a van but gives no sizes. Lol.
