Re: not your average carb lift plate post
[Re: johnnyd]
#2646435
04/18/19 11:36 AM
04/18/19 11:36 AM
Posts: 52,972 Romeo MI
MR_P_BODY
This is how I have my Dom set up .. you can turn over the adapter to run the 750.. if you want a spacer put it under the adapter.. this is 2 intakes set up differently.. 1 is a W-9 and the other a W-5 EDIT How tall is your spacer plate.. I have run a 2" tall spacer under the adapter.. your not looking for strength .. your not lifting the engine with it.. you can lift the engine going straight to the intake bolts(carb bolts but I dont do that ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: AndyF]
#2646458
04/18/19 12:18 PM
04/18/19 12:18 PM
MR_P_BODY
I've seen it done but I wouldn't do it on my own engine. That aluminum casting isn't very thick and typically those cast adapters are made as cheap as possible using garbage grade material. You aren't talking about Boeing landing gear type of quality control. More likely, those cast adapters were made in a dirt floor shop in China. So no, I wouldn't mount a lift plate to a cast aluminum adapter even though the stress level is actually fairly low. That material in the casting is far better than some of my SB stuff.. one of my W-5 intakes is a perfect example .. that thing was piss poor and was returned ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: MR_P_BODY]
#2646616
04/18/19 09:15 PM
04/18/19 09:15 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I don't even like lifting by the intake!! But if you must just take the adapter off and lift by the intake.
[Re: hemi-itis]
#2646693
04/19/19 06:42 AM
04/19/19 06:42 AM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Yeah the adaptors are usually bottom grade material, I would work it without the adaptor.
68 Barracuda Formula S 340
[Re: johnnyd]
#2646733
04/19/19 09:02 AM
04/19/19 09:02 AM
MR_P_BODY
I have 4 points that I use for swapping engines.. I use a engine leveler with 4 chains 2 of the front points are on the motor plate.. I find it to be very quick.. I can have the engine and trans on the ground in about 1 hour.. I have pulled a engine at the track but now days I dont carry the engine crane anymore and save that kind of stuff for back at home ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: johnnyd]
#2646739
04/19/19 09:14 AM
04/19/19 09:14 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
seems like most are thinking not to lift from the spacer/adapter.
My reason of thinking about this was for between round engine swaps. I was thinking off having a carb / engine lift plate already bolted to my spare engine. I figure it might save a few minutes in an engine swap taking place at the racetrack I didn't have to unbolt carb adapters on the broken engine nor on the spare engine. And yes, I have swapped between rounds once- broke an engine in the first time trial at one of the 'small' races during million $$ bracket races so there were hours of time available to get the swap done. You seem to have your mind made up so as long as you sleep well at night do it. What's the worst that can happen.
[Re: pittsburghracer]
#2646743
04/19/19 09:43 AM
04/19/19 09:43 AM
MR_P_BODY
My reason of thinking about this was for between round engine swaps. I was thinking off having a carb / engine lift plate already bolted to my spare engine. I figure it might save a few minutes in an engine swap taking place at the racetrack I didn't have to unbolt carb adapters on the broken engine nor on the spare engine. And yes, I have swapped between rounds once- broke an engine in the first time trial at one of the 'small' races during million $$ bracket races so there were hours of time available to get the swap done. You seem to have your mind made up so as long as you sleep well at night do it. What's the worst that can happen. You could do what happened to me.. my engine lift gave way and the engine and trans came down on the front of the car.. the cyl on the lift bent due to the load.. now I have a bigger unit ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: johnnyd]
#2646744
04/19/19 09:45 AM
04/19/19 09:45 AM
Posts: 12,305 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
There are 8 flanges on the adapter that seem to me would be weaker than the connecting points on either the intake or the lift plate. Given the potential of dropping the engine in the heat of battle, the cost of the few minutes to R and R the adapter seems insignificant.
Are mounting small lift brackets to the engines and having an adapter already on the replacement engine out of the question?
Master, again and still
[Re: MR_P_BODY]
#2646884
04/19/19 03:50 PM
04/19/19 03:50 PM
Posts: 2,687 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have 4 points that I use for swapping engines.. I use a engine leveler with 4 chains 2 of the front points are on the motor plate.. I find it to be very quick.. Me too
2011 Drag Pak Challenger
