Page 1 of 3 1 2 3
Trick Flow sb heads #2632169
03/13/19 07:28 AM
03/13/19 07:28 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Will be available to buy in a couple of weeks
They have been produced and are sitting around assembled at Trick flow
They plan to dyno a set yet this month on a 408 test mule. Didnt think to ask Howard how the 408 was setup
Heads should be from 1900-22/2300 bucks fully assembled
The top range will have quality solid roller springs and ti retainers installed.
Intake is going to lag behind by a little bit
418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car
1.41 best 60 foot
6.52 @ 105.20
Re: Trick Flow sb heads [Re: B3422W5] #2632440
03/13/19 08:32 PM
03/13/19 08:32 PM
MO
cdp Offline
cdp  Offline
MO
Thanks for the update! I'm curious to see the numbers.
Re: Trick Flow sb heads [Re: cdp] #2632883
03/15/19 05:08 AM
03/15/19 05:08 AM
Weatherford, Texas
RapidusMaximus Offline
Weatherford, Texas
Subscribed...any particular vendor be getting them before anyone else?
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Trick Flow sb heads [Re: RapidusMaximus] #2632923
03/15/19 08:50 AM
03/15/19 08:50 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Keep us in the loop up
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Trick Flow sb heads [Re: RapidusMaximus] #2632931
03/15/19 09:03 AM
03/15/19 09:03 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I would guess Summit as a mass retailer. They have close ties to TF.
Re: Trick Flow sb heads [Re: cudadoug] #2632936
03/15/19 09:19 AM
03/15/19 09:19 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You could say that.
Try a search for “trickflow.com” and see what pops up in your browser.
Re: Trick Flow sb heads [Re: cudadoug] #2632955
03/15/19 10:01 AM
03/15/19 10:01 AM
AndyF Offline
AndyF  Offline
Yeah, they own them.
Re: Trick Flow sb heads [Re: AndyF] #2633274
03/16/19 09:52 AM
03/16/19 09:52 AM
Weatherford, Texas
Weatherford, Texas
Wow...well there ya go...guess that answers that question...lol
1968 Plymouth GTX
Re: Trick Flow sb heads [Re: RapidusMaximus] #2635507
03/22/19 09:29 AM
03/22/19 09:29 AM
GA
roadrunninMark Offline
GA
Any update on the release date?
Re: Trick Flow sb heads [Re: roadrunninMark] #2635510
03/22/19 09:39 AM
03/22/19 09:39 AM
AndyF Offline
AndyF  Offline
Should be soon. We have a set on order and Summit said they would be shipping in April.
Re: Trick Flow sb heads [Re: AndyF] #2635747
03/22/19 10:35 PM
03/22/19 10:35 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
It would be interesting to see a back to back test vs the pro maxx shockers.
A new iron curtain drawn across the 49th parallel
Re: Trick Flow sb heads [Re: 67autocross] #2636169
03/23/19 08:48 PM
03/23/19 08:48 PM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
I called Promaxx last week because I was interested in the cnc'd heads. They said 4 to 6 weeks before they would have any sb Mopar heads.
Im also curious about the Trick Flows. Maybe they'll be out one day...
Re: Trick Flow sb heads [Re: dagohman] #2636332
03/24/19 10:08 AM
03/24/19 10:08 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Pro Maxx must have sold out of them, a local shop has a 408 going on the dyno in the next few weeks with them and are shooting for 600hp. The heads look good and CNC work is nice.
Re: Trick Flow sb heads [Re: 67autocross] #2636359
03/24/19 10:45 AM
03/24/19 10:45 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Any ported aluminum replacement head better make 600 on a flattop shortblock with some squeeze
Even with a healthy flat tappet.
1.41 best 60 foot
6.52 @ 105.20
Re: Trick Flow sb heads [Re: B3422W5] #2640131
04/02/19 09:55 AM
04/02/19 09:55 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
They start getting shipped Fri.
People will have them in there in hand next week
1.41 best 60 foot
6.52 @ 105.20
Re: Trick Flow sb heads [Re: B3422W5] #2640391
04/02/19 07:51 PM
04/02/19 07:51 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
On our local Dyno I don’t think I know of a pump gas small block that has gone over 600hp unless it had some of the moved push rod W2 or Indy heads on ...I’m assuming if this one can do it with the pro max heads the trick flows should be around the same.
Re: Trick Flow sb heads [Re: 67autocross] #2640468
04/02/19 10:17 PM
04/02/19 10:17 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
A zero deck stroker motor with flattops will be well over 12 to 1 with these heads.. it should make over 600 with a suitable cam.
1.41 best 60 foot
6.52 @ 105.20
Re: Trick Flow sb heads [Re: B3422W5] #2640475
04/02/19 10:51 PM
04/02/19 10:51 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Most of the small block builds around here are pump gas stroker 408-416 inch jobs with a max at say 11:1 that make under 600hp...after that they jump up 700hp and up stuff with big heads and aftermarket blocks. I don’t recall anyone I know really building at 12:1 stroker with a stock style head, this is most likely because it would need race gas and not really make a bunch more power....I’m going to see how this pro maxx stroker does on the dyno before I buy a top end for my stroker.
Re: Trick Flow sb heads [Re: 67autocross] #2640499
04/03/19 06:25 AM
04/03/19 06:25 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
A 12.5 to 1 stroker will ET a lot better than than a 10 to 1 stroker.
I could care less about having to run race gas. It wont be a daily driver. Might run 100 gallons of fuel through it a summer. Thats700 bucks. Thats putting around town and racing maybe 8 outings a summer
1.41 best 60 foot
6.52 @ 105.20
Re: Trick Flow sb heads [Re: B3422W5] #2643382
04/09/19 06:11 PM
04/09/19 06:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
IMM has pictures of the new cylinder head on their Fakebook page.
Rich H.
Esse Quam Videri
Page 1 of 3 1 2 3
