source for 3/4" tall o2 sensor bungs
#2645437
04/15/19 04:32 PM
04/15/19 04:32 PM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
I am planning to set up a pair of headers for dyno testing with 8 O2 sensors. (because I have 8 carbs) I bought some weld bungs from summit, but they are only 1/2 thick. The O2 sensor protrudes 1" past its flange, so that would leave 1/2" of the sensor in the tube. The dyno guys says that is enuff to affect performance. Does anyone know of a source for 3/4" thick steel O2 bungs. M18x1.5 is the thread. Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: source for 3/4" tall o2 sensor bungs
[Re: Hemi_Joel]
#2645454
04/15/19 05:07 PM
04/15/19 05:07 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Check out Amazon. Lots of different ones on there.
[Re: pittsburghracer]
#2645465
04/15/19 05:43 PM
04/15/19 05:43 PM
Hemi_Joel
Minnesota
I've been searching the web including amazon, ebay and summit. The search functions and descriptions mostly omit length. I'm hoping someone here knows a source.
[Re: justinp61]
#2645486
04/15/19 07:16 PM
04/15/19 07:16 PM
Posts: 11,538 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have an old Dynomax 88103 here that's 5/8" thick. Not sure I've ever seen one thicker. The threads on the sensors aren't that long. I suppose you could weld a bung to a thick washer/spacer and weld that assembly onto the pipe.
[Re: Hemi_Joel]
#2645500
04/15/19 07:55 PM
04/15/19 07:55 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
[Re: geo.]
#2645565
04/15/19 11:12 PM
04/15/19 11:12 PM
Hemi_Joel
Minnesota
You guys have some great ideas! I just ordered a set of 8 spark plug anti foulers from rock auto for $2.24 each.
[Re: Hemi_Joel]
#2645620
04/16/19 07:21 AM
04/16/19 07:21 AM
Posts: 10,021 MN
JERICOGTX
MN
I could have just made, and welded spacers to your existing bungs before welding them to the headers, at my work.
69 GTX
68 Road Runner
[Re: @#$%&*!]
#2646757
04/19/19 10:13 AM
04/19/19 10:13 AM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
At full throttle the depth won't matter as much for accuracy but if you're looking to tune part/light throttle conditions it's actually helpful to have more of the O2 sensor tip in the exhaust stream. There is a reason the bungs have a standard height.
I actually milled the bung depth down on a set of headpipes for my Harley as the closed loop control wasn't very good at light throttle due to poor O2 signal at low exhaust flows.
