Re: 72-up Big Block Truck Motor mounts [Re: trucklovinphil] #2645621
04/16/19 07:39 AM
04/16/19 07:39 AM
Western Colorado High Desert
moparmarks Online penguin-006
moparmarks  Online Penguin-006
Originally Posted by trucklovinphil
straight mounts are 2 wheel drive, other mounts with cutout for oilpump are for 4 wheel drive.
Partly correct.
72-4 4wd have a divorced transfer case and use the straight mounts.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 72-up Big Block Truck Motor mounts [Re: moparmarks] #2647223
04/20/19 12:23 PM
04/20/19 12:23 PM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Now a question for you guys. Will the 4x4 mounts fit on a 2wd? I'm pretty sure I have the 4x4 ones on my 2wd. I remember having a little trouble getting the engine dropped in.
Re: 72-up Big Block Truck Motor mounts [Re: moparmarks] #2647254
04/20/19 01:44 PM
04/20/19 01:44 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted by moparmarks
Originally Posted by bboogieart
I hope these are right, as I bought a set of those as well as ram horn manifolds and a water pump to put a big block in my '78.
If 2wd yes
Yes it is and thanx up
I have mechanical Aptitude.
I can screw up anything.
