340 Exhaust Manifolds Heat Sheild? #2644555
04/12/19 10:23 PM
04/12/19 10:23 PM
Shopping @ HoBo Fright
340SIX Offline OP
Doc Flappergas's Evil Twin
340SIX  Offline OP
Not the 68-71 ones.
I have a set of 1973 ones that I need them for. does anyone make new ones?
Also, what does the spring look like for the heat riser?
Looks to be in good order and free but the small pin is rusted that the spring goes on.
I blasted painted and cleaned up the ports.
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: 340 Exhaust Manifolds Heat Sheild? [Re: 340SIX] #2644557
04/12/19 10:27 PM
04/12/19 10:27 PM
340SIX Offline OP
340SIX  Offline OP
They are stock 1973 340 ones 2863553 and 2863549
Re: 340 Exhaust Manifolds Heat Sheild? [Re: 340SIX] #2644560
04/12/19 10:39 PM
04/12/19 10:39 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I drilled and tapped the hole for the rusted pin and made a new pin out of a screw/bolt. I just sold a partial heat riser kit with the springs. They look like this.
Re: 340 Exhaust Manifolds Heat Sheild? [Re: mopars4ever] #2644777
04/13/19 04:55 PM
04/13/19 04:55 PM
340SIX Offline OP
340SIX  Offline OP
The Spring for the heat riser is fine on that side as shown I am missing everything on the side that shows no parts.
Anyone have a picture of what goes there and How it looks on there.
The Flapper moves free and easy. And that pin on that side is fine. It is the pin on the side that is missing. The small one is thin but will work. they large one {main one is fine} looks like it has a Spring or something that goes between the 2 of them. That is what I m asking about.
Need the Spark Plug Heat shield for the driver side is that Reproduced?
Re: 340 Exhaust Manifolds Heat Sheild? [Re: 340SIX] #2644778
04/13/19 05:10 PM
04/13/19 05:10 PM
md
mopars4ever Offline
mopars4ever  Offline
md
only thing on that side is the small spring. It goes from pin to shaft. It sits in the grooves on the thin pin and on the flapper shaft groove.so it doesn`t side off. sure you can use the rusted pin if you want. I didn`t know if it was flimsy or not.
Re: 340 Exhaust Manifolds Heat Sheild? [Re: mopars4ever] #2644833
04/13/19 09:07 PM
04/13/19 09:07 PM
340SIX Offline OP
340SIX  Offline OP
Thanks i thought it was a,spring or clip. I did not know what it looks like. Do not think I still have it.
I knew a,spring or some thing when there as the small pin is,raised at the edge to keep it on it and the large pin / shaft is grooved for a,wire spring
Any chance of a picture of the Spring so I can get something?
Re: 340 Exhaust Manifolds Heat Sheild? [Re: 340SIX] #2644837
04/13/19 09:13 PM
04/13/19 09:13 PM
340SIX Offline OP
340SIX  Offline OP
Sorry, I could not open pictures on this phone it is that spring to the right of the picture right?
No need for a shield. I can see now that it is not a Sheild to protect the Spark Plug Wires. It goes to the Air Cleaner and I am running an Oval one.
Was hoping someone was gonna,say oh the reproduce those lol..
These have been off the car for 20 years
