Edelbrock SB Pro Flo Port EFI #2644409
04/12/19 12:48 PM
04/12/19 12:48 PM
Chicago, IL
P
PLUM_72 Offline OP
PLUM_72  Offline OP
P
Chicago, IL
Anyone use the Edelbrock port EFI system? Just wondering how it would compare to a Holly Sniper or FI Tech throttle body system. Is it worth the extra expense, fit under a standard e-body hood, tuning, etc...
https://www.edelbrock.com/pro-flo-4-efi-kit-for-big-block-chrysler-318-360-c-i-d-engines-35900.html
1972 Dodge Challenger
Re: Edelbrock SB Pro Flo Port EFI [Re: PLUM_72] #2644412
04/12/19 01:03 PM
04/12/19 01:03 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
It depends on your usage. If that kit comes with everything pictured that seems like a good value. It just doesn't seem like edelbrock has a whole lot of these systems out there.
I did use the same manifold on my 500HP 360. It could really use some porting and it is pretty tall. I was able to get it under the hood on my 68 Barracuda using a drop base air filter.
68 Barracuda Formula S 340
