Master cylinder for 1970 Cuda 440 manual drum brakes #2644241
04/12/19 12:58 AM
04/12/19 12:58 AM
Alabama
David1971 Offline OP
Alabama
Searching for a correct master cylinder for my September, 1969 built Cuda 440. It has its original manual drum setup: 11'' x 3" up front and 11"' x 2 1/2" at the rear. MBM brakes offers a new reproduction, but I know nothing about the company or their products. I think it is a Chinese casting. I have attached a picture of their model MC1323 with a 1 inch bore. It looks very similar to the original Bendix. Should I try to find a rebuildable core? Other options?
Thanks,
David
Re: Master cylinder for 1970 Cuda 440 manual drum brakes [Re: David1971] #2644894
04/14/19 12:30 AM
04/14/19 12:30 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
There are a million rebuildable cores out there of that MC - there are multiple part numbers that could be correct. It could say 2808577 or ANFF cast in the bottom. Also some had a wire for the cap instead of the bolt.
Re: Master cylinder for 1970 Cuda 440 manual drum brakes [Re: Morty426] #2645021
04/14/19 11:39 AM
04/14/19 11:39 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Bolt type for manual drum, challenge on old date coded M/C is the bore condition. Sleeving is an option if you really want OE original.
68 Charger
70 Cuda
