Stage V engineering Hemi conversion heads #2643101
04/09/19 08:08 AM
04/09/19 08:08 AM
USA
hudsonhornet7x Offline OP
USA
Any opinions on Stage V conversion heads? What else do you need to make them run?
Re: Stage V engineering Hemi conversion heads [Re: hudsonhornet7x] #2644239
04/12/19 01:06 AM
04/12/19 01:06 AM
dogdays Offline
dogdays  Offline
Ask them!
http://www.stagev.com/pages/hcheads.html
IIRC it's all explained in words and pictures.
R.
Re: Stage V engineering Hemi conversion heads [Re: hudsonhornet7x] #2644250
04/12/19 02:23 AM
04/12/19 02:23 AM
Don't even think of doing that tsk
Every thing I've read on here about them has been bad about them down
Re: Stage V engineering Hemi conversion heads [Re: hudsonhornet7x] #2644265
04/12/19 03:07 AM
04/12/19 03:07 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
There was a time when Hemi blocks weren't available so there was a need, not so much anymore.
A friend built one of the conversions back in the early 90's (he still has it).
The RB Block isn't nearly as strong in the bottom end as a true Hemi block, no cross bolted mains on a standard RB Block.
Re: Stage V engineering Hemi conversion heads [Re: SNK-EYZ] #2644345
04/12/19 10:33 AM
04/12/19 10:33 AM
Get-X Offline
Get-X  Offline
Not trying to stir the pot, but where today are Hemi blocks available that aren't $8k KB blocks or used up OE blocks for $6k+ in need of repair?? shruggy
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Stage V engineering Hemi conversion heads [Re: Get-X] #2644355
04/12/19 11:03 AM
04/12/19 11:03 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Slim pickin's out there.
But now that the supply is low, folks are cashing in and who can blame them...
This one sold yesterday (not mine)
https://www.ebay.com/itm/NEW-MOPAR-PERFORMANCE-DIRECT-CONNECTION-426-HEMI-ENGINE-BLOCK-NEW-/264270095224?item=264270095224&vxp=mtr&ViewItem=&nma=true&si=tyiY2mkj9Xkdqmp63dg2bCg8VL0%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
Rich H.
Esse Quam Videri
Re: Stage V engineering Hemi conversion heads [Re: ZIPPY] #2644363
04/12/19 11:20 AM
04/12/19 11:20 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Damn. But, if it's what you "have to" have, then I guess that's the going price. Which brings us back to the OP's question about this conversion.
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Stage V engineering Hemi conversion heads [Re: hudsonhornet7x] #2644371
04/12/19 11:31 AM
04/12/19 11:31 AM
Zumbrota,MN
als499 Offline
als499  Offline
Zumbrota,MN
I had one that Dick Landy built in the 90's pump gas 440 block 496" made 660hp and ran 10.50's in a 69 Road Runner . It was a very expensive build at the time and likely about the same cost as building with a regular hemi block. The heads flow alot of air and they look cool. If you had an industrial 413 block , 440 crank , you could use a standard 426 piston for a relatively cheap build.
Re: Stage V engineering Hemi conversion heads [Re: ZIPPY] #2644379
04/12/19 11:43 AM
04/12/19 11:43 AM
Get-X Offline
Get-X  Offline
I don't blame them at all, if I had one and was selling it I would get as much for it as possible.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Stage V engineering Hemi conversion heads [Re: Get-X] #2644507
04/12/19 07:10 PM
04/12/19 07:10 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
So what if you used these on a 400 block? Stronger bottom end,larger bore and if you stroked probably a lighter piston. Any thoughts?
Real Men shift for themselves
Re: Stage V engineering Hemi conversion heads [Re: 1DGEMAN] #2644519
04/12/19 08:21 PM
04/12/19 08:21 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Probably hard to find an intake for that combination.
Re: Stage V engineering Hemi conversion heads [Re: bobby66] #2644556
04/12/19 10:27 PM
04/12/19 10:27 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
stage v offers one
Ok
Re: Stage V engineering Hemi conversion heads [Re: 1DGEMAN] #2644562
04/12/19 10:42 PM
04/12/19 10:42 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
A few yrs ago I almost started one with my 400 block. A friend with a machine shop has done a few with cross bolted blocks & has a few cross bolted ones left. Stage 5 told me back then that the total cost for heads, valvetrain & intake was around $5700. I read an old Moparts post about one with a 400 block had pushrod/valvetrain problems but can't remember all the post said. I'd love to do one with a cross bolted 400 block.
Re: Stage V engineering Hemi conversion heads [Re: Triggerfish] #2644581
04/12/19 11:32 PM
04/12/19 11:32 PM
All the pictures I've seen of stock Mopar wedge(B and RB) cross bolted blocks had the bolts going through the main webbing on the center three main caps, NOT good tsk twocents
Re: Stage V engineering Hemi conversion heads [Re: Cab_Burge] #2644739
04/13/19 01:31 PM
04/13/19 01:31 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
If he's still got one, I'll see if I can get a pic & info.
Re: Stage V engineering Hemi conversion heads [Re: hudsonhornet7x] #2645263
04/15/19 08:36 AM
04/15/19 08:36 AM
an8sec70cuda Offline
The way block availability is now, I think the conversion kit is a viable option. If I was in the market, I'd definitely be looking into it.
Anyone remember Steve Magnante's (from Hot Rod magazine, B-J Auction, etc.) red hemi dart? That was a Stage V conversion on a 440 block if I'm not mistaken.
Lets be honest here...most people building a hemi aren't looking to make block breaking power. Less than 600 hp is what most seem to be after and a stock block will last a long time doing that.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Stage V engineering Hemi conversion heads [Re: an8sec70cuda] #2645380
04/15/19 12:51 PM
04/15/19 12:51 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Why build a Hemi If your looking for 600 or less shruggy
Re: Stage V engineering Hemi conversion heads [Re: RATTRAP] #2645382
04/15/19 01:00 PM
04/15/19 01:00 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Originally Posted by RATTRAP
[quote=an8sec70cuda]
The first answer would be the guy building a hemi clone.
Re: Stage V engineering Hemi conversion heads [Re: RATTRAP] #2645391
04/15/19 01:36 PM
04/15/19 01:36 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That was my question too, about 20 years ago smile
Rich H.
Esse Quam Videri
Re: Stage V engineering Hemi conversion heads [Re: RATTRAP] #2645394
04/15/19 01:46 PM
04/15/19 01:46 PM
While I agree w/ your thinking (mine makes 4 digit HP), there are a lot of car show and cruiser guys that just want the look. Or have just always wanted a hemi. Back when they were available, I bet the "little" 465 hp crate hemis outsold the 600+ hp 528" crates 10 to one.
CHIP
