Check your fuel lines (brand x ) #2643278
04/09/19 03:15 PM
04/09/19 03:15 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Friend , ran this car for a few years at local track .. found out , he has Twins on the way ..wife asked him to sell car .
It went to east coast somewhere and the fuel line burst at about 1/8 mile I believe , it got hurt bad .. but, driver ok
It was a Aluminum line , it split open
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Check your fuel lines (brand x ) [Re: bigdad] #2643280
04/09/19 03:24 PM
04/09/19 03:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That is a bummer to see that vehicle damaged, looks like it is a nice car. Repairable without too much trouble hopefully.
I'm not a fan of aluminum fuel line.
Whoever built the first two drag pak vehicles used that stuff. When I drove 2008001 (first prototype Drag Pak, the same one
Garlits drove), I had trouble with it...it stumbled badly. Every injector was plugged with red anodizing that had come off the fuel line.
It came apart and got the turbo and all that, afterwards.
Cue a poster who has used it since 1972 and never had a problem in 3.......2.......1.......:
Rich H.
Esse Quam Videri
Re: Check your fuel lines (brand x ) [Re: ZIPPY] #2643286
04/09/19 03:49 PM
04/09/19 03:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Not me, I hate the stuff. Cheap way out that seldom works well. Even quality hose has a lifespan and won't last forever in use with fuel. The next time I see "good" hose look like a lawn sprinkler when it's pressurized after sitting for a while, won't be the first.
Re: Check your fuel lines (brand x ) [Re: CMcAllister] #2643288
04/09/19 03:54 PM
04/09/19 03:54 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I gave a whole roll away as refuse to run that crap. Between seeing results from it splitting and guys fighting fuel issues because of it kinking it’s been long gone.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Check your fuel lines (brand x ) [Re: pittsburghracer] #2643306
04/09/19 04:41 PM
04/09/19 04:41 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
iagree I hate that aluminum crap and refuse to use it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Check your fuel lines (brand x ) [Re: bigdad] #2643309
04/09/19 04:45 PM
04/09/19 04:45 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
This is why we sell Safecraft fire extinguisher systems.
Fires suck!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Check your fuel lines (brand x ) [Re: RylisPro] #2643477
04/09/19 11:50 PM
04/09/19 11:50 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
I'm looking at plumbing my build for fuel. What are y'all s recommendations? Pro's and con's of each. We have an excellent example of why not use the aluminum line.
Re: Check your fuel lines (brand x ) [Re: RylisPro] #2643480
04/10/19 12:00 AM
04/10/19 12:00 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Fires suck!
Safecraft system in my Dakota.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Check your fuel lines (brand x ) [Re: Adobedude] #2643484
04/10/19 12:24 AM
04/10/19 12:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I ran alum line for about 1 1/2 years with zero issues but at that time
I was changing from ladder bars to a 4-link so I changed my chassis
and fuel system(basically build a new car but with the old body) I went
with the black cloth covered line(both supply and return).. I have the same
set up on my Rampage also
wave
Re: Check your fuel lines (brand x ) [Re: MR_P_BODY] #2643518
04/10/19 07:18 AM
04/10/19 07:18 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I use and like the black cloth covered AN line. I used Fragola for %90 of my fittings and all of the hose.
68 Barracuda Formula S 340
Re: Check your fuel lines (brand x ) [Re: ZIPPY] #2643520
04/10/19 07:22 AM
04/10/19 07:22 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
GUILTY as charged....
I’d horse traded and got the Duster about a year before we moved to AZ... My dad started racing it and “upgraded” things along the way. One was a new fuel system that included aluminum line from the pump to the regulator. So yes.... about 18 years now.
Since I’m hemorrhages $$$ from the wheelstand episode, maybe it’s time... the way my luck has been, better sooner than too later.
....I’m sure autozone has a roll of rubber line and some hose clamps I could score laugh2
Re: Check your fuel lines (brand x ) [Re: J_BODY] #2643766
04/10/19 06:59 PM
04/10/19 06:59 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
I've used alum. 'fuel line' in the past.. but now I have only one good use for it
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Check your fuel lines (brand x ) [Re: bigdad] #2643772
04/10/19 07:26 PM
04/10/19 07:26 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Guilty ran it for 26 yrs. Redoing the cuda but will be upgrading the entire system. It won't have aluminum this time. There are way more choices now vs early 80's and I'm not a poor college student any more.
Ok
Re: Check your fuel lines (brand x ) [Re: cudatom] #2643775
04/10/19 07:43 PM
04/10/19 07:43 PM
Get-X Offline
Get-X  Offline
I have a brand new coil of it still in the box from Mancini that came to me in a trade with a bunch of other stuff. It still sits there untouched. I have however used it in the past and haven't run into any problems, but it was always something in the back on my mind that I'd worry about.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: Check your fuel lines (brand x ) [Re: Get-X] #2643826
04/10/19 08:40 PM
04/10/19 08:40 PM
I've used soft drawn aluminum tubing purchased at local hardware stores as well as the anodized inner and outer aluminum fuel line coils from Summit with no issues so far shruggy
I bought some steel thin wall hydraulic tubing for my new race car but I don't think I can bend it without messing it up so maybe I'll have to do something else for it whiney
Re: Check your fuel lines (brand x ) [Re: Cab_Burge] #2645211
04/14/19 11:00 PM
04/14/19 11:00 PM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
If I'm not mistaken, isnt the cloth covered line lighter than steel braided?
Re: Check your fuel lines (brand x ) [Re: wyldebill] #2645264
04/15/19 08:42 AM
04/15/19 08:42 AM
Yes it is. Easier to work w/ too.
CHIP
Re: Check your fuel lines (brand x ) [Re: an8sec70cuda] #2645304
04/15/19 10:17 AM
04/15/19 10:17 AM
moparx Offline
moparx  Offline
what would the weight difference, say in a B-body, be between 1/2" steel line vs the same size in the cloth coated line ? a weight per foot would be a good enough comparison. TIA as always !
beer
Re: Check your fuel lines (brand x ) [Re: moparx] #2645951
04/17/19 08:53 AM
04/17/19 08:53 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
My -8 Aeroquip startlite with fittings is 3.6 ounces a foot. The hose is 1.3 ounces a foot.
I have an old 6” long (hose length not including the swivels ends) stainless braided line the is 3.9 ounces.
The black line in those pics is 1” and it weighs .1 ounces an inch.
Each fitting weighs 1.3 ounces. The biggest weight loss will be eliminating connection points.
E0C3CC4D-6911-4288-8C0D-9AE12937BF9A.jpeg82759BE9-FFFE-482F-8FC1-F570B7A37A5C.jpegD175828D-48A6-47E4-9C3D-71390E5BCCF6.jpeg
eBay-cdwmotorsports
Re: Check your fuel lines (brand x ) [Re: cdwmotorsports] #2645967
04/17/19 10:02 AM
04/17/19 10:02 AM
PA.
"Little"John
"Little"John
PA.
Until I get under 170 pounds I refuse to weigh fuel lines and fittings. And I’m willing to bet big money that will never happen. 😂
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
