Will powder coated rims chip when mounting tires?
#2643174
04/09/19 11:12 AM
04/09/19 11:12 AM
fullmetaljacket
Just thinking of powder coating rims and was wondering if anyone had issues with any chipping when mounting new tires on a tire machine.
I do have the option of triggering my talents with the rattle can and paint the rims instead if there may be a problem with powder coated surfaces.
Thank you.
Re: Will powder coated rims chip when mounting tires?
[Re: fullmetaljacket]
#2643175
04/09/19 11:14 AM
04/09/19 11:14 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
They do make no touch tire mounting machines that are specificallt designed to not damage rims when mounting tires. Find a tire ship with one of those.
#2643176
04/09/19 11:19 AM
04/09/19 11:19 AM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
Modern tire machines won't. Really old ones will.
Ex: Modern police Charger, black steel wheels, powder coated from the factory...There aren't many rusty ones running around....
Rich H.
Esse Quam Videri
[Re: Pacnorthcuda]
#2643179
04/09/19 11:22 AM
04/09/19 11:22 AM
Posts: 26,000 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Modern "Euro" tire changers grip the inside of the rim, not the center hole.
[Re: Pacnorthcuda]
#2643213
04/09/19 12:26 PM
04/09/19 12:26 PM
Posts: 3,337 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
These days it all depends on the Neanderthal operating the machine. This ...I've had both good and bad experiences lately
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
#2643234
04/09/19 01:20 PM
04/09/19 01:20 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
It will only chip if the powder coating is not fully cured (not enough heat when applied).
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
#2643254
04/09/19 02:10 PM
04/09/19 02:10 PM
Posts: 6,224 JERSEY
RJS
JERSEY
I don't much worry about how the rim itself is secured to the machine (my man has a modern installer machine and is very careful under my watchful eye) but I do worry about the baton gadget/pry bar they use to pry the tire onto the rim while the round house spins the rim. You guys get me?
Just trying to save aggravation and $$ before hand. Lee I get you and also feel you!!! usually they have a plastic cover on the metal bar that may be used in the install. Ron
[Re: RJS]
#2643320
04/09/19 05:05 PM
04/09/19 05:05 PM
Posts: 22,732 Bitopia
jcc
Bitopia
I hear you on the chip rims concern. Wait till you drop off a really nicely polished 150Lb Semi alum wheel for a tire change, and the tech flips it over alum side down on the dirty concrete without batting an eye, on the offset center mount, the scratches seldom polish out. I try to always bring a clean door mat, but then I have to stand there and make sure they use/position it.
[Re: DaytonaTurbo]
#2643577
04/10/19 10:09 AM
04/10/19 10:09 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Our machine at work back like 10 years ago we had a piece that went over the arm to keep from scraping rims etc.Mounted many including my Harley rims with no problems.Havent seen a center type machine since the 80s.Rocky
Chrysler Firepower
[Re: rumblefish72]
#2643710
04/10/19 03:03 PM
04/10/19 03:03 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Pardon my ignorance, The powder coat is not harder than paint? If so why use it? Personally, I sand blast and paint my own steel rims and never any troubles. Even after several changes. Also no trouble with aluminum rims. I take all my wheels to the local garage. He has been in business since the '70's. Equipment is as old. I do make sure Fran does the werk and not one of the kids. He gets a tip, and all is in cash so no invoice.
I have mechanical Aptitude. I can screw up anything.
