Will powder coated rims chip when mounting tires? #2643174
04/09/19 11:12 AM
04/09/19 11:12 AM
fullmetaljacket Offline OP
Just thinking of powder coating rims and was wondering if anyone had issues with any chipping when mounting new tires on a tire machine.
I do have the option of triggering my talents with the rattle can and paint the rims instead if there may be a problem with powder coated surfaces.
Thank you.
Re: Will powder coated rims chip when mounting tires? [Re: fullmetaljacket] #2643175
04/09/19 11:14 AM
04/09/19 11:14 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They do make no touch tire mounting machines that are specificallt designed to not damage rims when mounting tires. Find a tire ship with one of those.
Don't be the exception.
Re: Will powder coated rims chip when mounting tires? [Re: fullmetaljacket] #2643176
04/09/19 11:19 AM
04/09/19 11:19 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Modern tire machines won't. Really old ones will.
Ex: Modern police Charger, black steel wheels, powder coated from the factory...There aren't many rusty ones running around....
Rich H.
Esse Quam Videri
Re: Will powder coated rims chip when mounting tires? [Re: fullmetaljacket] #2643177
04/09/19 11:19 AM
04/09/19 11:19 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
These days it all depends on the Neanderthal operating the machine. Modern tire machines are designed so that there doesn’t HAVE to be any contact to the wheel itself, other than the center pin locating the wheel. I just had a flat repair on a painted rim that was perfect, and the monkey chipped it all to hell near the lugs.....he obviously didn’t give a [censored] when securing the wheel with the machines lock nut.
Communication with the shop prior to them touching your stuff is key. What I really find odd it that most all of these places sell brand new wheels....are they going to chip a wheel they selling to a customer? No......
Re: Will powder coated rims chip when mounting tires? [Re: Pacnorthcuda] #2643179
04/09/19 11:22 AM
04/09/19 11:22 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Modern "Euro" tire changers grip the inside of the rim, not the center hole.
Re: Will powder coated rims chip when mounting tires? [Re: John_Kunkel] #2643196
04/09/19 11:57 AM
04/09/19 11:57 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I haven't had any problems with the local shop on either painted or powdercoated wheels, but they're careful.
The powdercoated wheels on one of my trucks are rusting, though.
On another set of wheels I had a clear powdercoating done, they wouldn't stan up to even the mildest cleaning.
I'll paint them from now on.
Re: Will powder coated rims chip when mounting tires? [Re: topside] #2643202
04/09/19 12:07 PM
04/09/19 12:07 PM
I don't much worry about how the rim itself is secured to the machine (my man has a modern installer machine and is very careful under my watchful eye) but I do worry about the baton gadget/pry bar they use to pry the tire onto the rim while the round house spins the rim. You guys get me?
Just trying to save aggravation and $$ before hand.
Re: Will powder coated rims chip when mounting tires? [Re: Pacnorthcuda] #2643213
04/09/19 12:26 PM
04/09/19 12:26 PM
home of the Buckeyes
Butterscotch71 Offline
Lost Title
Lost Title
iagree This
...I've had both good and bad experiences lately
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
Re: Will powder coated rims chip when mounting tires? [Re: fullmetaljacket] #2643234
04/09/19 01:20 PM
04/09/19 01:20 PM
Chicago
PurpleBeeper Offline
Chicago
It will only chip if the powder coating is not fully cured (not enough heat when applied).
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Will powder coated rims chip when mounting tires? [Re: fullmetaljacket] #2643254
04/09/19 02:10 PM
04/09/19 02:10 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Lee I get you and also feel you!!! usually they have a plastic cover on the metal bar that may be used in the install.
Ron
Re: Will powder coated rims chip when mounting tires? [Re: RJS] #2643320
04/09/19 05:05 PM
04/09/19 05:05 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I hear you on the chip rims concern. Wait till you drop off a really nicely polished 150Lb Semi alum wheel for a tire change, and the tech flips it over alum side down on the dirty concrete without batting an eye, on the offset center mount, the scratches seldom polish out. rant I try to always bring a clean door mat, but then I have to stand there and make sure they use/position it.
Re: Will powder coated rims chip when mounting tires? [Re: jcc] #2643344
04/09/19 05:59 PM
04/09/19 05:59 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Whenever I bring my hotrod tires in I tell them before they start to not throw the tire up on face of the rim so as to lather up the bead with soap. They never understand why I request it but the good guys respect my wishes and get tipped accordingly.
Ron
Re: Will powder coated rims chip when mounting tires? [Re: RJS] #2643355
04/09/19 06:22 PM
04/09/19 06:22 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have my own tire machine and have never chipped a wheel, powder coated or painted.
Re: Will powder coated rims chip when mounting tires? [Re: Morty426] #2643568
04/10/19 10:00 AM
04/10/19 10:00 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
They make epoxy and zinc primers for powder coating. They are baked on before the final powder coat is applied. Rim seem to see especially tough abuse so they would be a good place to think about using it instead of going straight over the metal.
I have a no mar bar for my manual tire changer. When removing the tire, the single nylon end rides along the lip of the rim. When installing a tire, the double nylon end rides along the inside of the rim groove (area hidden by the tire after it's on). The way it works is the only opportunity I have to damage a rim is while removing the old tire. The nylon end is soft enough that it doesn't damage anything. I have spare tips because the nylon end is not supposed to last forever. If I can do that at home with some cheap tools, any tire shop can do MUCH MUCH better.
Re: Will powder coated rims chip when mounting tires? [Re: DaytonaTurbo] #2643577
04/10/19 10:09 AM
04/10/19 10:09 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Our machine at work back like 10 years ago we had a piece that went over the arm to keep from scraping rims etc.Mounted many including my Harley rims with no problems.Havent seen a center type machine since the 80s.Rocky
Chrysler Firepower
Re: Will powder coated rims chip when mounting tires? [Re: DaytonaTurbo] #2643620
04/10/19 11:24 AM
04/10/19 11:24 AM
moparx Offline
moparx  Offline
daytona, do you have a link to that bar ? i made my own manual changer about 30 years ago, and i have a fair amount of rim tools that won't damage the rim, but i don't have that one. TIA !
beer
Re: Will powder coated rims chip when mounting tires? [Re: moparx] #2643661
04/10/19 01:12 PM
04/10/19 01:12 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Online content
rumblefish72  Online Content
beer
https://www.nomartirechanger.com/Mount_Demount_Bar_p/tc-mdbar.htm
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Will powder coated rims chip when mounting tires? [Re: rumblefish72] #2643710
04/10/19 03:03 PM
04/10/19 03:03 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Pardon my ignorance,
The powder coat is not harder than paint?
If so why use it?
Personally, I sand blast and paint my own steel rims and never any troubles.
Even after several changes.
Also no trouble with aluminum rims.
I take all my wheels to the local garage.
He has been in business since the '70's.
Equipment is as old.
I do make sure Fran does the werk and not one of the kids.
He gets a tip, and all is in cash so no invoice.
I have mechanical Aptitude.
I can screw up anything.
Re: Will powder coated rims chip when mounting tires? [Re: rumblefish72] #2644003
04/11/19 11:33 AM
04/11/19 11:33 AM
moparx Offline
moparx  Offline
thanks rumblefish ! up
beer
