1/2 shift 727
#2642746
04/08/19 01:43 PM
04/08/19 01:43 PM
Posts: 1,613 westerly, ri. usa
440lebaron
westerly, ri. usa
hi running FAST class 69 charger 426/499 hemi F78/15 tire. manual valve body, to much tire spin 1/2 shift. if I put the accumulator spring back in will it cushion the shift?? gary
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: 1/2 shift 727
[Re: 440lebaron]
#2642754
04/08/19 01:56 PM
04/08/19 01:56 PM
Posts: 11,760 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Yes. Changing the lever ratio and/or the spring load in the servo will as well. Changing those may also effect the 2/3 shift though.
Re: 1/2 shift 727
[Re: 440lebaron]
#2642757
04/08/19 02:07 PM
04/08/19 02:07 PM
Posts: 26,024 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The outer accumulator spring has NOTHING to do with cushioning the 1-2 shift but it's a good idea to have it for other reasons.
Re: 1/2 shift 727
[Re: John_Kunkel]
#2642788
04/08/19 02:59 PM
04/08/19 02:59 PM
440lebaron
westerly, ri. usa
HI I am referring to the spring that you normally remove and replace with a blocker rod when you install a manual valvebody, I thought the stock spring was for cushioning the shift
Re: 1/2 shift 727
[Re: 440lebaron]
#2642803
04/08/19 03:27 PM
04/08/19 03:27 PM
John_Kunkel
Rio Linda, CA
Yes, that is the outer accumulator spring and it only cushions the application of the rear clutch, has nothing to do with the 1-2 shift....oldest myth in the Mopar world.
Re: 1/2 shift 727
[Re: 440lebaron]
#2643008
04/08/19 10:33 PM
04/08/19 10:33 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
hi running FAST class 69 charger 426/499 hemi F78/15 tire. manual valve body, to much tire spin 1/2 shift. if I put the accumulator spring back in will it cushion the shift?? gary Try leaving in 2nd?
