72-up Big Block Truck Motor mounts #2642427
04/07/19 08:20 PM
04/07/19 08:20 PM
SE PA.
Q
QuickBpBp Offline OP
Q
SE PA.
Anyone tell me what these are exactly for I know that 2 wheel drive is different than 4 wheel drive. I know they are 72-up for a few years. Anyone have any photos to show differences. Willing to learn the differences as there is not much info out there.... I can post more pics if needed. Thanks in advance!
Re: 72-up Big Block Truck Motor mounts [Re: QuickBpBp] #2642453
04/07/19 08:58 PM
04/07/19 08:58 PM
Between Houston & Galveston TX
SattyNoCar Offline
Happy Birthday SattyNoCar  Offline
I had a (factory) big block (2wd) '77 truck 25 yrs ago. It's been my understanding that when the brackets are shaped like yours, they're for 4 wheel drive. When they are straight like pictured below, they are for two wheel drive (this is what my truck had).
John
Re: 72-up Big Block Truck Motor mounts [Re: SattyNoCar] #2642462
04/07/19 09:07 PM
04/07/19 09:07 PM
SE PA.
Q
Q
SE PA.
Thanks for the reply. Hopefully others will chime in and verify. Not only would I like to know exactly what they are but the differences for sure. Thanks again.
Re: 72-up Big Block Truck Motor mounts [Re: QuickBpBp] #2642523
04/07/19 11:26 PM
04/07/19 11:26 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Here is what I know.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 72-up Big Block Truck Motor mounts [Re: moparmarks] #2642619
04/08/19 09:02 AM
04/08/19 09:02 AM
SE PA.
Q
Q
SE PA.
Thanks Mark these look like a variation of the top right 4 wheel drive ones...
Re: 72-up Big Block Truck Motor mounts [Re: QuickBpBp] #2642626
04/08/19 09:22 AM
04/08/19 09:22 AM
moparmarks Offline
moparmarks  Offline
They do. Does the left side have a hole to clear the oil pump pressure spring nut?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 72-up Big Block Truck Motor mounts [Re: moparmarks] #2642853
04/08/19 05:03 PM
04/08/19 05:03 PM
SE PA.
Q
Q
SE PA.
No hole it's solid there...
Re: 72-up Big Block Truck Motor mounts [Re: QuickBpBp] #2642860
04/08/19 05:21 PM
04/08/19 05:21 PM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
They are cut in such an angle that misses the oil pump nut. Test fit them on a block with pump and see.
I just sold 2 sets of those.
Re: 72-up Big Block Truck Motor mounts [Re: QuickBpBp] #2643218
04/09/19 12:45 PM
04/09/19 12:45 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
This is just from memory, a long time ago I bought a set of brackets from a big block van, and it seems like they looked like that. I wound up buying the correct brackets new at the dealership. That should give an idea how long ago it was...
P.S. I was putting a 383 in a 2WD 73 Club Cab.
Re: 72-up Big Block Truck Motor mounts [Re: Jwilli500] #2643336
04/09/19 05:42 PM
04/09/19 05:42 PM
SE PA.
Q
Q
SE PA.
The engine came out of a 78 truck or ram charger it was in and running so should not be from a van.. Just trying to figure out whether 4 wheel drive or not. I am surprised people can identify for sure as I thought guys were messing with these old trucks...
Re: 72-up Big Block Truck Motor mounts [Re: QuickBpBp] #2643398
04/09/19 08:18 PM
04/09/19 08:18 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
In our area, any big block truck was pretty rare, we didn't have as many as some areas were blessed with.
When I was messing with big blocks in trucks, it was during my dirt track days (late 70s through about the mid 80s), what motor bracket came on what year truck was not of any concern of mine, my concern was that the brackets I had got the motor close enough I could make them work. It was easier to modify existing truck motor brackets to fit our need then it was to modify car brackets to work. Then we need to throw in the fact that there may have been 3 or 4 small block to big block swaps over that span of time.
Now we add in all those years since the mid to late 80s and you think I should trust my memory with any kind of certainty on these kind of things?
Good luck with that. Gene
Re: 72-up Big Block Truck Motor mounts [Re: poorboy] #2643698
04/10/19 02:41 PM
04/10/19 02:41 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I am trying to remember now. This was back in the 90's. My buddy bought a running/driving 76sh Dodge camper van with a 440. We pulled the engine from the van and dropped it right into his 83 D150 2WD pick up truck with headers. I don't remember needing or getting any different engine mount brackets. We had it going in the new truck the same day. I do remember grinding a radius in the driver side frame rail rather than ding the header tube. Man, did that truck fly...
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 72-up Big Block Truck Motor mounts [Re: SattyNoCar] #2643738
04/10/19 04:48 PM
04/10/19 04:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I hope these are right, as I bought a set of those as well as ram horn manifolds and a water pump to put a big block in my '78.
I have mechanical Aptitude.
I can screw up anything.
Re: 72-up Big Block Truck Motor mounts [Re: bboogieart] #2643887
04/10/19 10:16 PM
04/10/19 10:16 PM
moparmarks Offline
moparmarks  Offline
I hope tpighese are right, as I bought a set of those as well as ram horn manifolds and a water pump to put a big block in my '78.
If 2wd yes
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 72-up Big Block Truck Motor mounts [Re: moparmarks] #2643926
04/11/19 07:17 AM
04/11/19 07:17 AM
Coastal Maine
Mr onetwo Offline
Mr onetwo  Offline
Coastal Maine
These photos are off my totally stock 78 Ramcharger SE 440....hope they help
Re: 72-up Big Block Truck Motor mounts [Re: Mr onetwo] #2643927
04/11/19 07:19 AM
04/11/19 07:19 AM
Coastal Maine
Mr onetwo Offline
Mr onetwo  Offline
Coastal Maine
stock rubber mounts. Everything is packed away for a couple more weeks...if you want I will post up better detailed photos of the mounts off the engine.
Re: 72-up Big Block Truck Motor mounts [Re: Mr onetwo] #2644197
04/11/19 09:46 PM
04/11/19 09:46 PM
SE PA.
Q
Q
SE PA.
Thanks! That is them and the engine was a 78 these came from. They are identical. I guess now the next question... Is your Ramcharger 4 wheel drive? Thanks again!
Re: 72-up Big Block Truck Motor mounts [Re: QuickBpBp] #2644269
04/12/19 05:17 AM
04/12/19 05:17 AM
Coastal Maine
Mr onetwo Offline
Mr onetwo  Offline
Coastal Maine
Sorry...yes it is
Re: 72-up Big Block Truck Motor mounts [Re: Mr onetwo] #2644561
04/12/19 10:39 PM
04/12/19 10:39 PM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
I used 76 4x4 mounts in my 78 d300......worked fine.
Didn't know there was a difference back then.
Ed
Re: 72-up Big Block Truck Motor mounts [Re: QuickBpBp] #2645031
04/14/19 01:15 PM
04/14/19 01:15 PM
USA, Wisconsin Rapids
trucklovinphil Offline
straight mounts are 2 wheel drive, other mounts with cutout for oilpump are for 4 wheel drive.
