Re: 72-up Big Block Truck Motor mounts
[Re: trucklovinphil]
#2645621
04/16/19 07:39 AM
04/16/19 07:39 AM
Posts: 12,521 Western Colorado High Desert
moparmarks
straight mounts are 2 wheel drive, other mounts with cutout for oilpump are for 4 wheel drive. Partly correct. 72-4 4wd have a divorced transfer case and use the straight mounts.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2647254
04/20/19 01:44 PM
04/20/19 01:44 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I hope these are right, as I bought a set of those as well as ram horn manifolds and a water pump to put a big block in my '78.
If 2wd yes Yes it is and thanx
I have mechanical Aptitude. I can screw up anything.
