Thunk goes the radio #2642271
04/07/19 12:26 PM
04/07/19 12:26 PM
Rhode Island
jml19621 Offline OP
jml19621  Offline OP
Rhode Island
Hi all,
My father passed last June. He left a 79 Red express. He was having problems with the am/fm CB radio. It was working fine then stopped. I pusher the mike for the cb and the meter goes up like it is trying to transmitt. When I turn the unit on I get a thunk nose from the speakers. I removed the unit from the dash checked all the connections, nothing. Any thoughts before I jack it up, take off the inner fender shield and check the antenna connect?
Thanks Jeff
Re: Thunk goes the radio [Re: jml19621] #2642297
04/07/19 01:53 PM
04/07/19 01:53 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
You can remove the antenna from the top and look at it, no need to pull inner fender. Does the am/fm part work? If that works thinking it is connected.
Re: Thunk goes the radio [Re: 4406bbl] #2642309
04/07/19 02:45 PM
04/07/19 02:45 PM
Rhode Island
jml19621 Offline OP
jml19621  Offline OP
Rhode Island
No the am/fm does not have any sound.
