4.7 to 5.9 transplant
#2640902
04/03/19 09:08 PM
04/03/19 09:08 PM
Posts: 12,494 Western Colorado High Desert
moparmarks
Looking at some 2000-2004 Dakotas with the 4.7. What all is needed to change to a 5.9 ? Looking for a 5-spd but also interested in the interchange with a auto too. Many thanks
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
Re: 4.7 to 5.9 transplant
[Re: moparmarks]
#2641151
04/04/19 12:38 PM
04/04/19 12:38 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
trans, wiring harness, computer, motor mounts and a whole pile of small parts are different, you could get a harness and computer from a 318 truck to use the manual trans, they do bolt up but since the 5.9 never got the 5 speed there is no computer made for it, another option would be the 5.9 computer from a 3/4 or one ton but they had extra 02s so you would need to add them to keep off the CEL. The 4.7 flywheel will only work if it has the notches for the crank sensor to read. Whatever you get you pretty much need the exact year matching trucks for donors as the body computers and such need to match. I guess what it all boils down to is finding two trucks with the same computer systems and a 3rd heavy doody truck for the actual computer.
[Re: savoy64]
#2641979
04/06/19 01:43 PM
04/06/19 01:43 PM
HotRodDave
Kalispell Mt.
no 5.9 5 speed in a 1/2 ton or dakota, the factory didn't trust the nv3500 behind a 5.9 and the nv4500 was too clunky and truck like for the people who want a truck for a car.
