Main Seals & Pan Gaskets #2640506
04/03/19 08:11 AM
04/03/19 08:11 AM
E
earlymopar Offline OP
E
I'd like recommendations on main seal type and brand as well as pan gasket type and brand for a small block. I want to be sure I'm getting pieces that will provide the best opportunity to seal and will make for a quick and easy installation. This will be done not only on an assembled engine but one that is still in my pickup. Fortunately the pan is very accessible due to the pickup having a dropped axle.
Thanks,
- EM
Re: Main Seals & Pan Gaskets [Re: earlymopar] #2640518
04/03/19 09:00 AM
04/03/19 09:00 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Superfrormance gaskets
All you will ever use once you try them
Re: Main Seals & Pan Gaskets [Re: Dunnuck Racing] #2640569
04/03/19 10:31 AM
04/03/19 10:31 AM
E
E
Thanks Dunnuck. Are these available directly from SuperPerfornance or only through distributors like Summit, etc.?
- EM
Re: Main Seals & Pan Gaskets [Re: Dunnuck Racing] #2640585
04/03/19 11:16 AM
04/03/19 11:16 AM
E
E
OK. I found them. Thanks again.
- EM
Re: Main Seals & Pan Gaskets [Re: earlymopar] #2640609
04/03/19 11:51 AM
04/03/19 11:51 AM
Northern Indiana
Northern Indiana
Sorry I only get on here on occasion
Glad you found him, hes's a wealth of knowledge on engine sealing
Re: Main Seals & Pan Gaskets [Re: earlymopar] #2640614
04/03/19 12:05 PM
04/03/19 12:05 PM
There is no magic in making a motor seal up and not leak, the factory did it by the thousands for ever, correct work
Any good gaskets and seals should work fine up Cheap gaskets leak more than good gaskets do shruggy
As long as you install them correctly thumbsshruggy
Re: Main Seals & Pan Gaskets [Re: Cab_Burge] #2640626
04/03/19 12:26 PM
04/03/19 12:26 PM
#1 check pan rail straightness & end seal and side gasket fitment dry. some rear thin black seals are a bit too long to fit perfect in the main cap half moon groove & the half moon pan itself cutout in the front can be too shallow on some aftermarket pans forcing you to trim the end of the front black seal so with some compression it fits well & sometimes the side gaskets need to be sectioned so the holes in em line up dead on with the block holes & pan special attention to the (4) corner pieces that meet the ends of the black front/rear main seals, trim as needed. I hear good about the MP one piece gasket but ain't tried it (yet).
