Pushbutton Trans ID question #2639505
04/01/19 08:48 AM
04/01/19 08:48 AM
Charlotte, NC
Rutgersknight Offline OP
Charlotte, NC
Trying to ID my Trans in my 63 Polara, picture attached of ID number
F2464734 08643
I think it is a 1964 trans, just really want to make sure it is a Pushbutton 727 and not a column/console unit
I am having some trouble getting all the forward and reverse gears to work properly
I can adjust to so that the forward gears are fine, but then it doesn't fell like reverse is fully engaged
Is the Rooster Comb different for Pushbutton versus Column/Console Units?
Steve R
Steve R
Re: Pushbutton Trans ID question [Re: Rutgersknight] #2639581
04/01/19 11:02 AM
04/01/19 11:02 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If memory serves me correctly, the rooster comb is different as well as the manual valve.
They have to allow for the extra cable travel for the console gear cable to get to park position and an additional neutral in the valve.
I do not have picture handy, hopefully someone else will.
Re: Pushbutton Trans ID question [Re: TJP] #2639589
04/01/19 11:23 AM
04/01/19 11:23 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
column shift and console transmissions have a different valve body and rooster comb.
Re: Pushbutton Trans ID question [Re: lewtot184] #2639595
04/01/19 11:45 AM
04/01/19 11:45 AM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Helped a friend with this a while back , yes the rooster comb and the manual valve are different from pushbutton units and console shift units. Also the adjust was very time consuming as one hole made a difference in if it was correct or not.
Matt
Re: Pushbutton Trans ID question [Re: Rutgersknight] #2639598
04/01/19 11:59 AM
04/01/19 11:59 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
F2464734 is a '64 console-shift trans. You can use it with pushbuttons by using the '65 adjustment procedure i.e. make the adjustment with the shifter in 1 instead of R.
Re: Pushbutton Trans ID question [Re: John_Kunkel] #2639614
04/01/19 12:14 PM
04/01/19 12:14 PM
Charlotte, NC
Charlotte, NC
OK - Thanks for the information - very much appreciated
I will try readjusting using the 65 procedure
Steve R
Steve R
Re: Pushbutton Trans ID question [Re: lewtot184] #2640010
04/02/19 02:36 AM
04/02/19 02:36 AM
Cab_Burge Online work
Cab_Burge  Online Work
Not quite accurate, tskdifferent rooster comb, different manual valve and different shifter cable, the valve body castings where the same in column shift and floor shift cars is what I remember from back then, scope
What say you, John?
Re: Pushbutton Trans ID question [Re: Cab_Burge] #2640091
04/02/19 09:23 AM
04/02/19 09:23 AM
Charlotte, NC
Charlotte, NC
The transmission was rebuilt by Mancini years ago - I am pretty sure that the parts list included a Turbo Action Valve Body Part 17672 (62-64 Pushbutton)
Not sure what Rooster Comb is in there??
Steve R
Steve R
Re: Pushbutton Trans ID question [Re: Cab_Burge] #2640198
04/02/19 01:02 PM
04/02/19 01:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What say you, John?
Since the column/console valve body has the Park position added, the bore for the manual valve is bored deeper (actually bored clear through) for the extra travel of the valve.
