correct exhaust manifolds #2639585
04/01/19 11:10 AM
04/01/19 11:10 AM
K
karengarneau Offline OP
K
have a 71 340 duster which I believe is has all correct engine components.
my question is this....when looking at other 71 340 dusters most have the early style exhaust manifolds(68-70)
door sticker build date is 12-70
was told that early builds had the 68 style and at some time they changed over to the log style
so how do I tell which ones are correct for me as I need to replace the head pipes soon.
Thanks for all replies
Bennoel
Re: correct exhaust manifolds [Re: karengarneau] #2639603
04/01/19 12:08 PM
04/01/19 12:08 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No 71 340 A-Body's should have the 68-70 style exhaust manifolds. twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: correct exhaust manifolds [Re: Rhinodart] #2639801
04/01/19 06:48 PM
04/01/19 06:48 PM
K
K
That's exactly what I always thought.
After looking at several examples at MCACN I saw at least two 71 dusters with the early manifolds.
Asked the owners and they told me that they came like that. So now I don't know if it's a early production thing ?????
And also one 71 demon with the early manifolds as well.
Bennoel
Re: correct exhaust manifolds [Re: karengarneau] #2639831
04/01/19 07:42 PM
04/01/19 07:42 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The drivers side is the 68-70 style.
The passenger side is the log style in 71
Re: correct exhaust manifolds [Re: Morty426] #2639907
04/01/19 09:29 PM
04/01/19 09:29 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
All regular production 1971 A-body 340's had the same manifolds, early or not.
Re: correct exhaust manifolds [Re: ScottSmith_Harms] #2639937
04/01/19 10:23 PM
04/01/19 10:23 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I did mean to say the passenger side is log style, but you already knew that I am pretty sure.
A-Body's RULE!
Re: correct exhaust manifolds [Re: Rhinodart] #2639962
04/01/19 11:04 PM
04/01/19 11:04 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Maybe this will help. These are 68-70 (pair) there are two versions of the drivers side, early and late. Both versions share the same casting numbers but the early versions have the casting numbers cast in the typical protruding fashion, later versions where the casting number was debossed (looks pressed into the cast iron surface, not protruding). The later versions started showing up sometime during the 1970 model year. The pair shown here are early versions
Re: correct exhaust manifolds [Re: ScottSmith_Harms] #2639964
04/01/19 11:06 PM
04/01/19 11:06 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
These are the 71 A-body Manifolds (Drivers side is the same used from 68-70, Pass side is new in 71 and fits 340 A-body, 340 E-body, and C-body 360 cars)
71 340 Exhaust Manifolds A-body.jpg71_340_Exhaust_Manifolds_B.jpg71 340 Exhaust 002.jpg
Re: correct exhaust manifolds [Re: ScottSmith_Harms] #2639966
04/01/19 11:07 PM
04/01/19 11:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
These are 71 E-body 340 manifolds
71 340 Ebody Exhaust Manifolds.jpg71 340 Ebody Exhaust Manifolds Numbers.jpg71 E-body 340 Exhaust mnfld back.jpg
Re: correct exhaust manifolds [Re: ScottSmith_Harms] #2643003
04/08/19 10:23 PM
04/08/19 10:23 PM
Middle TN.
4x4 Roundup Offline
4x4 Roundup  Offline
Middle TN.
Great info. thanks for posting. up
WANTED-- DEAD or ALIVE:
'70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car.
'79 Power Wagon W14JE9S137761 or 763
Re: correct exhaust manifolds [Re: 4x4 Roundup] #2643140
04/09/19 10:00 AM
04/09/19 10:00 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Anyone know the reasoning as to why two different heat riser counterweights were used on the 68-70 340 manifolds.
The thin ones shown in Scotts pictures and the thicker one, can both be found on assembly line 68-70 340 manifolds.
Could it be early verses later 68-70 manifold as I believe the thinner ones are more commonly seen.
Re: correct exhaust manifolds [Re: ScottSmith_Harms] #2651507
05/03/19 10:41 AM
05/03/19 10:41 AM
K
K
so first of all thanks to everyone for the info. after searching for the correct manifolds I have found two pass side manifolds which I'm told are correct for 71 340 a body. they both end in a 3 not 6. in other words I'm told 3418623 is correct. so maybe both are correct, one early one late ?????
