Duttweiler LS piston?
#2639123
03/31/19 10:09 AM
03/31/19 10:09 AM
Posts: 4,206 New York
polyspheric
New York
If anyone has read the HRM "Speed Demon" article, the piston shown is a bit of a puzzle (and the auto shop quality of the author leaves much to be desired). The LS is, obviously a quench chamber with tilted valves, and a chamber shape & volume designed to keep the CR in line with high boost. However: the dome is a bowl with a round island centered in it. In a valve face this is what DV called "penny on a stick". I think the island is not a compression bump that doesn't interfere with overlap flow, but something else. It may be relevant to Trick Flow etc. heads. Picture here: https://hotrodenginetech.com/speed-demons-ablown-fuel-streamliner-motorBefore I make a guess, any ideas?
Boffin Emeritus
Re: Duttweiler LS piston?
[Re: polyspheric]
#2639176
03/31/19 01:12 PM
03/31/19 01:12 PM
Posts: 4,457 Washington
madscientist
Washington
I'm going to guess here but I'm thinking that's a mixture motion piston top (my limited education stops me from giving a better description) to induce a more homogeneous mixture. Or maybe it helps suppress detonation in some way. At 60 pounds of boost for that time frame I'm sure that detonation is an enemy.
The thing that stuck out more than that to me, was the fact he was using a gapless top ring. Some would say the engine builder is stupid for that, because they don't work.
Just weird things you see sometimes.
[Re: sgcuda]
#2639205
03/31/19 03:07 PM
03/31/19 03:07 PM
polyspheric
New York
Thanks, that was sort of where I was going. A little circular running path for mixture to swirl instead of just being pushed down? Many smart people have said "the piston dome is the bottom of the combustion chamber", I just have this gut feeling that what we accept as choices now (dome, wedge, flat, dish) is shorter than the possible list, but what are they? This may be one for chambers resembling the LS.
Boffin Emeritus
[Re: polyspheric]
#2639211
03/31/19 03:27 PM
03/31/19 03:27 PM
polyspheric
New York
What I can't tell from the photos: is the OD of the trough also the outer edge of a circle outlining the LS chamber, and its ID determined by the edge of the intake valve? This would accept charge directly from the opening valve on O/L and give it both a place to go (less shrouding) and a direction. DV is very specific that if the intake flow isn't initiated ASAP there is no way to "catch up" by delayed intake closing. Not being able to analyze what's going on here in the B&ATDC O/L time period is very frustrating, I'm try to design a piston dome for a very weird chamber.
Boffin Emeritus
[Re: sgcuda]
#2639664
04/01/19 01:03 PM
04/01/19 01:03 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
My first thought was it was the direct injection liked the thing in the piston as they do have funky shaped pistons but that engine has all 3 injectors in the port so I would say it has to do with spinning the mix around as it comes in the chamber,
[Re: WO23Coronet]
#2640083
04/02/19 09:06 AM
04/02/19 09:06 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Many "dome" pistons really kill any charge motion in the cylinder as the piston approaches TDC. As it was mentioned, the piston crown has to be treated like the floor of the chamber.
This engine is not DI, and DI piston crown features are only present for catalyst light off, to keep a rich pocket of fuel at the spark plug. Pistons in central mounted DI injector engines will look similar, albeit less exaggerated, as they want to maintain some quench along the outside of the chamber, and you have to build up material in the center to gain back CR, but not so much as to "cut" the chamber in half at TDC.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
