How big can you bore a 1969 426 Hemi block?? #2638933
03/30/19 05:55 PM
03/30/19 05:55 PM
Virginia Beach VA
StevieD1966 Offline OP
Virginia Beach VA
I have a 1969 426 hemi block that is bored 60 over now. Can you go larger than 60 over and have special pistons made??
Re: How big can you bore a 1969 426 Hemi block?? [Re: StevieD1966] #2638935
03/30/19 06:06 PM
03/30/19 06:06 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
The only sure way to find out is to have the block sonic tested.
Re: How big can you bore a 1969 426 Hemi block?? [Re: Lee446] #2638946
03/30/19 06:29 PM
03/30/19 06:29 PM
Virginia Beach VA
Virginia Beach VA
Thanks, I'm taking the block on Monday to have it tested. I'm still wondering if anyone has bored a block more than 60 over?
Re: How big can you bore a 1969 426 Hemi block?? [Re: StevieD1966] #2638951
03/30/19 06:51 PM
03/30/19 06:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Check to see if you can find rings.. pistons can be made to any size
wave
Re: How big can you bore a 1969 426 Hemi block?? [Re: StevieD1966] #2638952
03/30/19 06:52 PM
03/30/19 06:52 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
.060" is about it...You can sleeve it though....I had one with 8 sleeves...ran it for years. My engine guy can do it so you can't even tell.
Re: How big can you bore a 1969 426 Hemi block?? [Re: Dragula] #2638955
03/30/19 06:59 PM
03/30/19 06:59 PM
Virginia Beach VA
Virginia Beach VA
Thanks, What would it cost to sleeve all 8 cylinders? Is it cheaper to buy a new block or can you find a new block?
Re: How big can you bore a 1969 426 Hemi block?? [Re: StevieD1966] #2638958
03/30/19 07:07 PM
03/30/19 07:07 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
New blocks are hard to find. Tons of them have been bored .070, have it sonic checked and then you'll know.
Sheldon
Re: How big can you bore a 1969 426 Hemi block?? [Re: StevieD1966] #2638962
03/30/19 07:22 PM
03/30/19 07:22 PM
The ring packages available for the stock 4.250 bore is some what limited but it is the same bore size as the 427 Chevy and 383 motors.
The stock 440 bore is 4,320 which is +.070 over 4.250 so ring packages should be good for your deal.
I've seen a lot of stock 426 blocks bored to 4.320 for NHRA SS back in the day and some even bigger on good blocks before Mopar started offering NHRA approved replacement blocks in the 1990s shruggy
Before deciding make sure and have it sonic tested by a good shop and go from there, I like to see at least .180 or more on both the major and minor thrust surfaces after boring honing scope
Some of the stock production blocks have a lot more than that stock(.330+) and some don't have as much as others confused
Re: How big can you bore a 1969 426 Hemi block?? [Re: RUNCHARGER] #2638977
03/30/19 08:15 PM
03/30/19 08:15 PM
Virginia Beach VA
Virginia Beach VA
Thanks!!
Re: How big can you bore a 1969 426 Hemi block?? [Re: Cab_Burge] #2638978
03/30/19 08:16 PM
03/30/19 08:16 PM
Virginia Beach VA
Virginia Beach VA
Great Thanks for the info!
Re: How big can you bore a 1969 426 Hemi block?? [Re: StevieD1966] #2638986
03/30/19 08:36 PM
03/30/19 08:36 PM
Dragula Offline
Dragula  Offline
PM me and I will give you his number...
Re: How big can you bore a 1969 426 Hemi block?? [Re: Dragula] #2638988
03/30/19 08:44 PM
03/30/19 08:44 PM
PA
1118Steve Offline
1118Steve  Offline
PA
.060 is pretty much standard on those old blocks. Got several of them here, been racing Hemis for close to 50 years. We started at Std., then went 020, 030. and 060 and then sleeved them back to standard. The one in the car now is .060 over. Most of them are. Most of the used old blocks you'll find around are 60 over. Years ago, Herb McCandless was marketing 70 over pistons, but, for some reason it never really took off. Sleeving is expensive. But, a Hemi block is worth it.
"Old Age and Treachery beats youth and enthusiasm"
Re: How big can you bore a 1969 426 Hemi block?? [Re: Dragula] #2638989
03/30/19 08:50 PM
03/30/19 08:50 PM
gregsdart Offline
gregsdart  Offline
I ran a 426w block at .100 over for years, till i drove over the crank!😢
How bad are the bores now? If they can clean up at .002 to .003, you could go with .060 + .005 rings and pistons made to fit? If you only have one or two bad cylinders, you could sleeve them and bore to match? Do anything you can to keep the bore from having to be bored to the next size, to add life to the block!
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: How big can you bore a 1969 426 Hemi block?? [Re: gregsdart] #2639097
03/31/19 08:28 AM
03/31/19 08:28 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Had one already + .060 that went to + .062 after checking it, no problems. "Your mileage may vary"...
Re: How big can you bore a 1969 426 Hemi block?? [Re: StevieD1966] #2639177
03/31/19 12:15 PM
03/31/19 12:15 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
My last Iron motor was .070 over.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: How big can you bore a 1969 426 Hemi block?? [Re: W.I.N. Racing] #2639251
03/31/19 04:58 PM
03/31/19 04:58 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
I have one that is .65. After sonic check it was .80 on the thrust side of 2 cylinders. Will need a resleeve
